Go to Post At this time of the season, there is only one response: BAAAAAAAAA-humbug! - dlavery [more]
Unread 20-05-2004, 19:03
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Potentiometer
Does anyone know where I may get a good potentiometer? I'm looking to design some new controls and a potentiometer would be the only way to do what I'm looking for.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 20-05-2004, 20:43
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: Potentiometer
Check Radioshack. our small store has pots, and they look similar to what we used this year (i'm not an electrical dude, just trying to help).
Unread 20-05-2004, 21:48
Joshua May's Avatar
Go Bears!
Re: Potentiometer
Thanks for your help, just what I needed.
Unread 20-05-2004, 22:09
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
Re: Potentiometer
www.newarkinone.com and www.future-active.com are two sites with very large catalogs of electronics parts including potentiometers of all kinds.
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Unread 20-05-2004, 22:21
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Re: Potentiometer
find a fry's it is all you will need
Unread 21-05-2004, 14:52
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Potentiometer
Digikey is another source with a variety of types available. Know your size limits, what diameter shaft and mounting bushing (if any) you need and the power dissipation required. (1/2 watt, 1 watt, etc.)
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-05-2004, 23:11
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Team Role: Coach
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
Re: Potentiometer
What would be the best wattage if it were to be hooked up to the 2004 RC? 2004 OI? If I remember, we hooked up a 100k, 1/4 watt, pot that I got from Jameco and it got fairly hot and tripped the OI, but I think when we used them on the RC it worked fine. Hmmm? I fairly sure we wired it correctly to the PORT pinouts.
Unread 22-05-2004, 12:21
Unsung FIRST Hero
Rookie Year: 1996
Re: Potentiometer
1/2 watt or 1 watt should be fine.
Al
WB9UVJ
www.wildstang.org
Unread 22-05-2004, 19:51
Mike Ciance Mike Ciance is offline
FRC #0025 (Raider Robotix)
Mike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant future
Send a message via AIM to Mike Ciance
Re: Potentiometer
if you have any old joysticks you don't need anymore, try taking them apart. each joystick contains 2 pots. also, if you want help with designing you own custom anolog control mechanism, you should talk to my team. we made a "voodo" arm controller that won us the innovation in control award at the jersey regional
Potentiometer with BS2 sanddrag Programming 7 13-05-2004 19:21
pic: Team 1414 Potentiometer CD47-Bot Robot Showcase 14 12-04-2004 14:48
Potentiometer Problem Greg General Forum 1 15-02-2003 18:10
Bourns Inc Potentiometer archiver 2000 2 23-06-2002 23:06
Potentiometer Theory Ulibrium Technical Discussion 6 25-01-2002 21:16
