Go to Post ... poets, novelists, songwriters, these people are word engineers. - MissInformation [more]
Unread 05-20-2004, 08:22 PM
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
White Paper Discuss: Code and Walkthrough for Global Positioning System using IR Sensors
Thread created automatically to discuss a document in the White Papers.
Code and Walkthrough for Global Positioning System using IR Sensors by Grommit
Unread 05-20-2004, 08:54 PM
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
Re: White Paper Discuss: Code and Walkthrough for Global Positioning System using IR Sensors
Just a couple of questions and comments:
1. Satellite GPS does not use the angle the signal is traveling at, it uses the distance from the satellite to the device
2. I believe that you do not need to use your "firstrun" variable and loop to initialize the static variables, i believe you can just define statics when you declare them
Code:
static int myVar = 5;
and the definition will only happen the first time the function is called, so the variable won't be changed by the definition/declaration statement in successive function calls.
3. Have you run this code on a FRC? It seems like it, along with the neccesary parts of the default code, could start to cause "default_routine" to start missing cycles as some people have mentioned has happened, if this code is running in every cycle in "default_rountine".
I like the use of a 4th sensor for error correction, pretty cool. If you have used this system, how did it work, if not, post about it when you do.
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Unread 05-20-2004, 09:22 PM
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Very cool. My only concern is speed with floats. As maxlobovsky said, it can cause it to miss cycles. My thought is to do this either in parts (state machine), or do getdata and putdata in the middle of it.
