Go to Post Are you prepared to be a team member? - JaneYoung [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 21-05-2004, 18:20
psychoCHIPMUNKK's Avatar
psychoCHIPMUNKK psychoCHIPMUNKK is offline
Technical Manager
#0241 (Last Minute Fix)
Team Role: Driver
psychoCHIPMUNKK has a little shameless behaviour in the past
Send a message via AIM to psychoCHIPMUNKK Send a message via Yahoo to psychoCHIPMUNKK
Spring Compression in Inventor 6?
Does anyone know if it is possible to make a spring expand and compress when using driving constraints? I'm trying to show that the spring is attached to two different surfaces, and when they move, so does the spring. The spring was made using a coil, and I know that in the part file it assigns a parameter value for the height (which is what would be changed) but i'm not sure how to access that parameter in a sub assembly. Any help would be great.
Team 241
NEW Spring Off Season in NJ Wayne C. Off-Season Events 25 11-06-2004 10:21
Compression Crisis reisser 3D Animation and Competition 9 22-02-2004 11:23
Legality of Spring Loaded Pistons Yan Wang Pneumatics 13 19-02-2004 17:20
Bosch Drill Motor Clutch Spring Dimensions?? aaronbr28040 Motors 3 18-02-2004 19:52
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
