Go to Post "So we have an arm, and the pot on it tells how high we are... ...and then we know how high we want to be... ...and if we're not high enough we go higher." (I have to leave the room, we're all laughing too much.) - demosthenes2k8 [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 04-03-2002, 02:03
Undefined One Undefined One is offline
#0114 (Eagle Strike)
Undefined One is an unknown quantity at this point
Question Framerate?
I've got a question about a little bit of information that I strangely haven't been able to find anywhere...: What is the framerate of the animation supposed to be?
Latest specs that I know:
640x480 AVI, Cinepak compression
Hmm, that's another question: To what quality should it be compressed?
Thanks!
Unread 04-03-2002, 06:23
Don's Avatar
Don Don is offline
#0288 (the RoboDawgs)
Don is an unknown quantity at this point
Send a message via AIM to Don
Highest quality and I believe you're supposed to render at the NTSC (is that the right acronym?) standard which is about 30 fps. I haven't seen any official rulings but these are my best guesses.
Unread 04-03-2002, 07:21
ComBBAT_Albrot's Avatar
ComBBAT_Albrot ComBBAT_Albrot is offline
#0021 (ComBBAT)
ComBBAT_Albrot is an unknown quantity at this point
Send a message via AIM to ComBBAT_Albrot
Yeah, 30 fps is just about the standard... higher might not play right, and lower makes your animation seem amateurish.
It's really quite depressing that Cinepak codec at "highest quality" looks terrible. If FIRST would concede and let us go with a DivX compression, I would be a happier camper.
Unread 04-03-2002, 21:15
Ranma Ranma is offline
#0831 (Ka Mikini O Hui Mililani)
Ranma is an unknown quantity at this point
Send a message via AIM to Ranma
Cinepak is EXTINCT compression type, I don't know why FIRST won't let us use DivX (maybe cuz it requires high system specs to use). It would be good if we used anything but Cinepak, something like Indeo or otherwise. NTSC standard frame rate is actually 29.97 fps, which can be rounded up to 30. Don't use anything higher than 30 though, it's just a hassle in 3DS Max and you only get a marginal increase in animation at double the size of the file. Also, does anyone know if we can compress the audio?
Unread 04-03-2002, 22:19
Unsung FIRST Hero
Nate Smith Nate Smith is offline
FRC Key Volunteer Trainer
AKA: CrazyNate
Rookie Year: 1998
Nate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to behold
Send a message via AIM to Nate Smith Send a message via Yahoo to Nate Smith
The only reason I can think of why Autodesk(note: Autodesk was the one making the ruling on this, as they're the ones doing the judging, not FIRST) would have chosen Cinepak over anything else is that they can guarantee that every system out there has it...Cinepak is included with just about every current version of Windows, and so everybody's got it. Opening up to a choice of codecs means that one of two scenarios would take place:
-every team would have to include an installer for the codec they used, and the judges at Autodesk would have to install all of them(possibly up to 700+!).
-some team would end up not getting judged because the file they sent in couldn't be read on the judges' machine.
Nate Smith
nsmith@smythsoft.com
12 seasons, 4 teams, and more time logged behind the scorekeeper's table than I care to remember...
returning for 2011? only time will tell...
Unread 14-03-2002, 19:26
MSTBoss MSTBoss is offline
#0905 (Paradox)
MSTBoss is an unknown quantity at this point
Send a message via AIM to MSTBoss
Question Compression
I was under the impression that work was to be submitted "UNCOMPRESSED"?? 640x480
Unread 14-03-2002, 19:27
Team905Animator's Avatar
Team905Animator Team905Animator is offline
Mission Control
AKA: Casey Williams
FRC #0905 (Platt Tech Panthers)
Team Role: Leadership
Team905Animator is on a distinguished road
Send a message via MSN to Team905Animator
Didnt the guidelines in the rulebook say that the .avi needs to be submitted uncompressed?
Unread 14-03-2002, 20:51
#0021 (ComBBAT)
It did, but don't be fooled! One of the Team Updates (I forget which at the moment) revised it and specified a 640x480 animation compressed with the Cinepak Codec. An uncompressed AVI would never fit on a CD, ye gods!
Unread 14-03-2002, 22:42
Ydnar's Avatar
Ydnar Ydnar is offline
#0932 (Circuit Chargers)
Ydnar is an unknown quantity at this point
Send a message via AIM to Ydnar
Question
why do they require the size be 640 x 480??? it shouldn't really make a difference becuase they will blow it up to be full screen no matter what... is it just another one of those things that really has no point except to make things stadard
-Come and go, and rise and fall with glory, maybe one day i'll be famous too
Unread 16-03-2002, 18:21
Sunny Thaper Sunny Thaper is offline
None #0064 (The Gila Monsters)
Team Role: Animator
Rookie Year: 1998
Sunny Thaper is an unknown quantity at this point
Send a message via AIM to Sunny Thaper
Cool
640 x 480 probably is easier for the Autodesk video guys to work with when they branch it off to a VHS. Also, TVs don't have that good of a resolution, there's are actually lower than 640x480 so your animation won't look much better if it was 1024x728 or something like 1600x1200.
