Go to Post "Fair and professional" needs to be two-directional. - John Neun [more]
Unread 29-05-2004, 13:00
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Question Template Project
I'm making a Template Project. What do you want in it?
Unread 29-05-2004, 13:12
AKA: Jamie Bliss
Re: Template Project
Here's my list:
  • Kevin's Interupts.c
  • TTL support (Flag to redirect Printf()s to TTL?)
  • Variables.c/.h
  • multiple autons
  • flags.h
    Code:
    #define __NO_PRINTF_
    #define __EDU_RC_
    #define __USE_TTL_
    //etc...
  • sgn, abs, absdif (macros, math.h)
    Code:
    #define sgn(Number) ( (0 - ((Number) < 0)) || ((Number) > 0) )
    #define abs(Number) ( ((Number) < 0) ? (0 - (Number)) : (Number) )
    #define absdif(Num1,Num2) ( ((Num1) < (Num2)) ? ((Num2) - (Num1)) : ((Num1) - (Num2)) )
  • EDU & FRC (flag)
  • // C++ style Comments
  • main.c bug fixed
  • Botalias.h
  • Kevin's EDU RC code?
  • DoData macro.
    Code:
    #define DoData ( (statusflag.NEW_SPI_DATA) ? (Getdata(&rxdata) | Putdata(&txdata)) : 0)
Unread 30-05-2004, 02:49
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Originally Posted by Astronouth7303
Here's my list:
This would be kinda cool. Can I suggest that you look into adding a circular buffer too? For extra credit, how about making it interrupt driven?
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 30-05-2004, 09:08
AKA: Jamie Bliss
-Kevin
"Gah!" -JVN
I'll see what I can do...
Unread 30-05-2004, 14:06
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
wun will become famous soon enough
Send a message via AIM to wun Send a message via MSN to wun
Something to make tweaking variables easer would be really nice (you know, for those situations where you need to get the deadzone on the joystick just right or tweak the speed so the right motor goes a little slower).
Help Microsoft stop piracy. Use Linux!
I have three gmail invitations, message me if you want one
Unread 30-05-2004, 17:13
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
Some teams created a command prompt, via a terminal program, to change constants and make other changes to the robot without uploading new code.
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Unread 30-05-2004, 19:08
AKA: Jamie Bliss
Originally Posted by maxlobovsky
yeah, like a little mini command prompt that some teams use.
I don't know what your talking about, but this is entirely within the standard MPLAB project. So add:
  • Interpret_Data()
for checking that sort of thing. The challenge is making it extremely flexible and general, yet doing that sort of thing easily, W/O BLOAT.
Unread 30-05-2004, 20:04
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
Thats a really good idea! How is it done? Do you know where I can take a look at the code?
Unread 30-05-2004, 20:05
Fold em oval!
Well by some teams, i only meant one specific example, but I'm sure there are more. Let me see if I have can get permission to post the relevant part of the code.
Team 1257
Unread 29-05-2004, 13:24
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
You might add some debug/test routines. E.g.,
Code:
Set_Debug_Level (HIGH); // or maybe Set_Debug_Level (5), etc.
debug (msg, threshold); // i.e., if debug level < threshold, print msg
eq (some_var, some_val, severity); // i.e., if some_var!=some_val do action based on severity
// etc., more tests/debug features
Just a thought ... it's nice sometimes to write code based on certain tests, and since you don't always have the robot with you while coding, it can be helpful to print out errors where something unexpected occurrs, but then have it go silent when you are doing the competition ... but still have it ready to go if you change something and need to make sure it all works. Wow, I'm going to stop rambling now.
Unread 29-05-2004, 13:31
AKA: Jamie Bliss
No, no. that's the point. And it's better than mine, I think.
Math project edomus General Forum 4 01-04-2004 13:12
Preseason project AdamT General Forum 4 09-09-2002 00:52
project box archiver 2000 2 23-06-2002 23:01
physics project SharkBite General Forum 10 03-03-2002 22:06
MS Project Build Schedule joe_balint Technical Discussion 1 07-01-2002 03:25
