Go to Post ...never do something because it is comfortable, do something because you WANT to do it. - Andrew Schreiber [more]
Go Back   Chief Delphi > ChiefDelphi.com Website > CD Forum Support
Unread 02-06-2004, 14:09
Melissa Nute's Avatar
Melissa Nute Melissa Nute is offline
I like my hammer...
Melissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond repute
Send a message via AIM to Melissa Nute
message too short error
Half of the time I try to post and I have a reply, an error message telling me my "message must at least be 2 characters long" shows up. I retype the message and it still shows up.
This may just be my computer being stupid.
Unread 02-06-2004, 14:15
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Rookie Year: 1998
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Re: message too short error
What browser [and full version] and operating system are you using?
Also, is this on a quick reply, or normal reply screen.
Also, are you using the WYSIWYG editor [basic or advanced] or standard plain-jane input.
Brandon Martus
e-mail
Unread 02-06-2004, 14:18
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
See that? ^
Ok, well if you hit the "reply" button on the bottom right of the post that you are replying to it will make you quote someone.
If you hit the "post reply" button on the bottom left of the thread, then you don't quote someone.
But, the story does not end there... oh no no no....
I have found out that if you hit the "reply" button and type within the quoted area, then it does not see it as you typing anything in there.
You have to type outside of the original quoted area, which I am doing now.
Hope this helps, I ran into that a few timese before and that's the only thing I can think that you are doing to get the message.
If worse comes to worse, you can hit the "reply" button but delete the [ quote ] & [ /quote ] at the beginning and end of the original quote in the text editor.
I had to do that when replying to the 2004 survey thread, so I didn't have to type all the questions over again.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 02-06-2004, 14:20
I like my hammer...
Internet Explorer. Version 6.0.2 on Windows XP Home Edition
On the normal reply screen...it isn't letting me use the Quick Reply
WYSIWYG editor...I really have no idea if it is basic or advanced
Unread 02-06-2004, 15:05
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
it isn't letting you use quick reply? That may be related...
Even if you type out a big message, it doesn't work? and the form is cleared? I would suspect security settings, but not sure.
Unread 02-06-2004, 19:33
busy.
AKA: B. Slash Kamen
Rookie Year: 1998
Can you run a Windows Update, and make sure you have all the patches for IE.
Also, are you using threaded, hybrid, or linear mode to view the topics?
Brandon Martus
e-mail
Unread 02-06-2004, 22:17
I like my hammer...
I've ran a windows update.
I'm using the linear method.
Wait...the windows update fixed the problem.
Unread 03-06-2004, 00:02
busy.
AKA: B. Slash Kamen
Rookie Year: 1998
glad to hear.
Brandon Martus
e-mail
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Error message in MPLAB IDE dddriveman Programming 11 18-03-2004 06:34
hexidecimal error message in notepad Anthony Kesich Programming 6 09-02-2004 18:42
Header File error message Mike Yan Programming 2 09-02-2004 11:31
