Go to Post First, corndogs and now cowbells... when will you make the pain stop, Frank?!?!?! - barn34 [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 06-06-2004, 00:09
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Rookie Year: 1999
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Setting up Apache2...
I am trying to install Apache2 on my computer which I built a few months ago which I planned to use as a HTTP file server and other stuff. I downloaded it and instaled Apache but it gives me erros saying its not connected to my IP address and I've tried uninstalling and retrying different configurations withing the start up install screens. It is also saying that it cannot start service 'Apache2'. This is running on an XP Pro machine with dual 2GHZ AMD 256MB DDR 80GB HD (soon to be 1TB) on an SDSL line. The computer runse very stable except for this task. Could anyone help me try to get the configurations correct please. I am finally doing this to help F.I.R.S.T. Teams which need a place to host files or simmilar idea (saw info about the remote control car and wanted to host for them)
Unread 06-06-2004, 07:36
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Re: Setting up Apache2...
I'll IM you later, but I'll say, are you running as an administrator and do you have any other server type programs running?
Unread 06-06-2004, 10:03
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
I am totally unable to help you except to suggest a good place for asking specific questions like you have. http://www.webmasterworld.com/
There is a specific section on Apache http://www.webmasterworld.com/forum92/
You need to register to ask questions, but that is free. You will find great community there very much like what you find here at CD.
Unread 06-06-2004, 10:31
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Hwello,
I am not very familiar with Apache 2.0.49 (if that is still the latest version under Windows), but instead I use Apache 1.3.31. I have found through much experimentation under Windows XP Pro, Apache 2.0.x is very fast, while Apache 1.3.x is very stable. Anyone with any knowledge as to why, please enlighten me.
If the error message you are getting is something like "Apache cannot bind to this IP address", open your httpd.conf file (by default, c:\program files\apache group\apache2\conf\httpd.conf) and change the binding IP address to 0.0.0.0. This directs Apache to try and listen for connections on all IP addresses on that computer. If that does not work, change the server port from 80 to something obscure, like 63733. If Apache works after changing the server port, then there is another program listening on port 80, that needs to be axed before you can run a webserver.
If you need any help at all, please PM me. If you want to see the config file for my webserver (http://endeavour.zapto.org/), go to http://endeavour.zapto.org/httpd.conf.txt. My server is running Apache 1.3.31 on Windows 2000.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 06-06-2004, 14:08
Stefan's Avatar
Stefan Stefan is offline
FRC #1002 (The CircuitRunners)
Stefan is on a distinguished road
Send a message via AIM to Stefan
I have Apache2 running stable fast and pimp on XP pro SP1 alolng w/ MySQL 4.0.18 and PHP 4.3.2. IM me at SCOUT2005 on AIM if you still have problems.
Member of RoboJackets
-- GT Aerospace Major
-- Alumni - FRC No. 1002 CircuitRunners (03 - 05)
Unread 06-06-2004, 23:52
Pierson's Avatar
Pierson Pierson is offline
Rookie Year: 2000
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
Unless you have an affinity towards windows XP or you want to continue using it as a work station, I might suggest switching to a Linux based OS. While I have some servers running Mandrake and SuSE, the easiest to install and administer is a free Red Hat based distro called Clark Connect . It is very easy to use, just download the ISO and install it. Do understand though, that this will become the sole OS for the computer and that there is no GUI.
It comes with Apache, FTP, Mail, and other servers either installed or ready to be installed.
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 07-06-2004, 21:04
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
It would greatly help if you could post the exact errors and your httpd.conf file.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 08-06-2004, 19:18
Mike AA's Avatar
AKA: Mike Aalderink
Rookie Year: 1999
Thank You everyone that helped me out with this. I finally got Apache to work and got the website linked to it. I will be getting a full fledged website set up then getting file sharing setup. I will be involved as a volunteer on a new F.I.R.S.T. Team this year ( I was on 74 for the last 6 or so years ). This server will be the location of our teams website and I will be setting it up much like 108 did with the movie files and make it available to be uploaded and downloaded. It'll have plenty of space to store each years competitons at high quality.
Again Thanks for all your help!
setting autonomous mode Allison Programming 10 08-03-2004 20:37
Speed Controller brake/coast setting steven114 Electrical 21 03-03-2004 13:05
Need help setting up phpBB on a coolfreepages.com website LBK Rules Website Design/Showcase 5 30-03-2003 20:02
3dmax - setting a display option that I can't find DanL 3D Animation and Competition 5 05-01-2003 12:42
Jealousy is setting in now!!!! archiver 2000 5 23-06-2002 23:46
