Go to Post Welcome to CD, side effects aren't limited too, but may include, addiction to mechanical and electrical assemblies, desire to program in C, drawing objects in Solidworks and subconscious learning! - Jay H 237 [more]
Unread 08-06-2004, 13:22
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
12v regulator
Not really a question, just thaught that maybe someone might have a use for this, I designed it for use on an ATV, I am powering something of of the stator coil, and the voltage spikes would kill my sensitive electronics, and I just thaught that it would be possible for someone out there to use delicate electronic componets on the bot, so this simple circuit would keep you from fryin a part, wont fix and undervolt situation, but certanly can save you the hassle of replacing electrical parts, this is definatly not for use on motors, the output curent max is 1 amp. you could beef this circuit up, but I dont know why you would, this was designed to work in harsh, mud filled, and other wise non-electronics friendly enviroments, hense the water tight housing.
http://www30.brinkster.com/technikube/vreg/12vreg.html
A note, the material the capacitors are made out of makes a differance.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 09-06-2004, 22:08
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: 12v regulator
Corey,
The voltage difference you note could be explained in a variety of ways. The meter could be introducing the error, the power supply feeding your circuit could be low. (You need at least 2 volts above the output voltage for the regulator to work, in this case V in should be greater than 14 volts. This is called the dropout voltage) or the variation in regulators (production variations.) produces this lower voltage. I am happy to get 11.8 -12.2 volts out of a 7812 especially the garden variety from Radio Shack.
By the way, if the input voltage allows(i.e. it is high enough), you can add diodes(banded end connected to ground) in series witht the ground pin to raise the ouptut voltage in 0.6 volt steps. Two diodes in series with the ground pin would give you 13.2, three diodes would give 13.8 volts.
Al
WB9UVJ
www.wildstang.org
________________________
12V Power Supply Feeds My Robot MikeDubreuil Electrical 17 31-03-2004 12:06
Jump Start RC w/o Exide 12v battery Mark McLeod Control System 3 12-01-2004 12:42
12V Tether pinout f22flyboy Electrical 10 01-11-2002 14:51
Portable 12V Power Supplies? archiver 2000 2 24-06-2002 00:19
