Go to Post Speculate away! - IndySam [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 12-06-2004, 00:08
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Using Linux?
I've used Knoppix a little, and a few more specialized CD / floppy distros.
I've also used Caldera (2.3), a few versions of Mandrake (6-8), Redhat (7.3 - 9), Suse (8.1) Gentoo, LFS, and Debian. Probably a few others that I've left out.
Unread 12-06-2004, 09:27
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Re: Using Linux?
What would one recommend for a beginner?
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 12-06-2004, 10:19
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
Re: Using Linux?
Mandrake is decent for a beginner, I've seen its slight more user friendly than others, but thats my view. If you need help installing feel free to IM me, I used to use dual boot a while ago, but uninstalled it because of disk space.
-Bharat
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 12-06-2004, 10:24
Rookie Year: 1997
Re: Using Linux?
I used Knoppix 3.2, I think.
For beginners, I like to make a couple of suggestions
Suse - just like German Engineered cars, Suse takes care of the small details very well. If I was recommending a distro for a business, this is it.
Fedora - Used to be Redhat, very nice, however they take the high rode when it comes to patent issues (which is good, except when you are trying to make the absolutely easiest use distro). They don't include MP3 or NTFS support, and a few other things. They can be easily added, though, by adding in third party packages.
Mandrake - Very up to date and includes everything Fedora/Redhat leaves out. However, in 3 or 4 version's I've tried, I've never gotten it to be as stable as linux should be (more on the level of windows).
If you were trying to learn linux very well, I'd suggest installing one of those and playing with them for a while, then installing Debian or Gentoo. I can help you with Debian, and Ian W. can help you with Gentoo. However, since you just want to get it running for you mom, I'd use one of the above three.
Unread 12-06-2004, 17:10
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Re: Using Linux?
I agree with the stabilty of Mandrake thing, but I'd say go with that at first.
Also, it has very nice NTFS support. So, if nothing else, get the first CD and use it to resize the XP partition(s).
And getoo is hard to install... good luck if you go for that.
Unread 12-06-2004, 17:27
Rookie Year: 1997
Re: Using Linux?
You can also resize NTFS partitions with qtparted, which is included with knoppix.
Unread 12-06-2004, 17:35
AKA: Eric Hansen
Re: Using Linux?
Really, Knoppix is only worth it if you partition your hd, and dual-boot it, in my opinion anways.
I'll probably figure something out during vacation, and do it when I return.
Y!: synsoflife
Unread 26-06-2004, 20:58
Timothy D. Ginn's Avatar
Timothy D. Ginn Timothy D. Ginn is offline
I check here maybe once a year.
Timothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to all
Send a message via ICQ to Timothy D. Ginn Send a message via AIM to Timothy D. Ginn Send a message via MSN to Timothy D. Ginn Send a message via Yahoo to Timothy D. Ginn
Re: Using Linux?
I'd recommend SuSE. SuSE's YaST is a very nice update/software install tool and makes finding software easy. The SuSE installer is quite good at coexisting with Windows partitions, it can even resize NTFS partitions to give itself some space, and does so by default (rather than overwriting your other partitions). It's also probably one of the most straight forward systems to install, as it gives you enough to have a nicely working system that's suitable for use by most desktop users and then you can get the rest of the stuff later using YaST as you require it. The FTP installer may be a bit slow (SuSE has a fair number of mirrors overseas) but with enough persistence you will succeed.
There's a 9.0 Personal version that does an install over FTP. 9.1 uses a 2.6 kernel, but 9.0 doesn't uses a 2.4 one.
If you need any help, feel free to contact me (that includes post-setup).
Alumni of FRC Team 1006
Former mentor of Full Lego Alchemist (FLL 5621) - Sempar School / Computing Students' Association of Queen's University
Unread 27-06-2004, 07:43
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: Using Linux?
Try CollegeLinux. It's based on Slackware, comes on 1 CD, and has a doc for Dual booting with WinXP. We just installed it on my brother's laptop, that went pretty good. (Know in advance, it's virtually impossible to change the resolution)
Unread 27-06-2004, 14:02
AKA: Eric Hansen
Re: Using Linux?
I'm 99.9% sure the ansewr is yes, but I'll ask anways. It's a very safe bet to backup your computer before doing any of this, correct?
Y!: synsoflife
Unread 27-06-2004, 14:44
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Re: Using Linux?
Absolutely. Backup before installing Linux. And after. And very very often.
One more thing - make sure that you can recover from your backups as well - all my backups used to be to CDs, but I have recently discovered that I can't read my earliest CD-Rs any longer, namely ones from before 1999.
If you want to get started with Linux, I think that Red Hat Linux 9 or Fedora Core (either 1 or 2) are excellent choices. Everything is already set up for you. I found it quite easy to install Red Hat 7.2 (back when I first started) and immediately I had a development environment, excellent GUI, and office tools (KOffice).
Eventually, you will get annoyed with the fact that Red Hat/Fedora has customized everything just a little, enough to cause frustration to people who like to understand the complete workings of Linux. Right now, I'm very significantly confused by the graphical bootscreen of Fedora Core 2 (how the hell do they do that?).
But yes, backup and good luck!
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 27-06-2004, 14:54
AKA: Eric Hansen
Re: Using Linux?
Is using the backup program that comes w/ Windows XP a good program? (Sorry for the newbie-ish questions here, but hey; why not). I'm going to test RedHat on a LiveCD, and see if I like it.
Y!: synsoflife
Unread 27-06-2004, 15:19
Re: Using Linux?
SuSE has that too. It's called a Bootsplash. Here's an outline of how it works (and how to change it):
http://www.bootsplash.org/
There's also more splash screens available on KDE Look (I believe it was somewhere within this category, but could be wrong)
http://www.kde-look.org/index.php?xsortmode=new&page=0
But that's a bit off topic, isn't it?
Unread 27-06-2004, 15:40
FRC #0030
Re: Using Linux?
I have never used the Windows XP Backup tool, but I have heard that its not that good.
But, why even bother with a backup tool? Find all the files that you use, will use, and have ever used (eg all documents, pictures, music, thesises, codes, novels, etc.) and copy those onto your backup medium of choice. I use CD-Rs in the absence of something better.
And btw, is there such a thing as a Redhat livecd?
Team 30, 2002-2005
  #15   Spotlight this post!
Unread 27-06-2004, 16:12
Re: Using Linux?
There isn't one pre-packaged as an ISO distributed directly by Redhat or the Fedora Project. It is possible to make one, of course, and there's most likely either a Redhat-derivative which is distributed as a LiveCD, or an "unofficial" LiveCD somewhere.
Knoppix and DemoLinux are Debian based, SuSE LiveCD is SuSE based (of course) and that covers the ones I've seen around lately.
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
Linux: steps to program fullsize RC robot rwaliany Programming 31 14-02-2004 14:45
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
RoboEmu for Linux (PBASIC emulator) rbayer Programming 5 21-11-2002 21:08
Linux file extensions rbayer CD Forum Support 5 14-11-2002 23:04
