Re: Using Linux?
As for the LiveCD, I ment SuSE, not RedHat (sorry). The LCD of SuSE is availible here if you want to check it out by the way. |
Re: Using Linux?
Re: Using Linux?
Re: Using Linux?
I have been using Linux (of many varieties) on FAT partitions. I do this because I don't care about security and FAT is universally accessible. There are a few caveats about doing this though.
First, you can't have symlinks. A direct consequence of this is that you cannot compile a linux kernel (as far as I know) on a FAT filesystem, as one step in the compile involves the creation of a symlink. Second, you lose all security. Any user can access any part of the filesystem. A non-root user can still do pretty much anything on a FAT system. Third, you lose many of the features of chown (change ownership), chmod (change mode), and ACLs. Even then, for my uses, the benefits of universal access of any OS to any OS far outweigh the problems. I wouldn't recommend doing this unless you are sure of what you are doing, but if you are sure of what you are doing, then there are better options. Until that Linux NTFS driver gets better. |
Re: Using Linux?
Actually, ReiserFS, ext2, and ext3 can all be read by Windows. Not natively, of course.. but with some work, you can get it to work.
Most notably: Explore2fs: http://uranus.it.swin.edu.au/~jn/linux/explore2fs.htm (r/w: ext2, ro: ext3) rfstool: http://p-nand-q.com/download/rfstool.html (read-only and ignore journaling) There might be some for jfs/xfs/etc.. but I don't feel like finding them E2fs works well, rfstool is.. decent.. but it does work. |
Re: Using Linux?
![]() I had to do some fun work on my own getting it back up. ![]() |
Re: Using Linux?
I just got a new laptop with Windoze XP Pro pre-installed. I installed Mandrake 9.2 as a dual boot.
At the partitioning step, I chose the "use free space on windoze partition" option, selected the new size of the windoze partition, and let 'er rip. At the final step, where you can review your installed services, etc. I went into the boot-loader options and selected the windoze option as the primary boot option. You might have to hunt around to find this option. Otherwise the linux will boot first. If you don't find this option and you boot into linux, you can edit the /etc/lilo.conf file and select another boot option. If you're not expert enough to know what I'm talking about here, you might want to cleanly install linux and fool around before going for the dual boot. Inside linux there's a "dual boot howto" which explains all this better. In any event, my Windoze XP and my Mandrake 9.2 linux are co-existing peacefully on the same machine now. |
Re: Using Linux?
Thanks ya'll for your help.
One other question, I know *nix is free, but would it be smarter to buy a copy of redhat or some other sort instead? |
#10
Re: Using Linux?
Re: Using Linux?
![]() I know the community is pretty big ; that's 1 reason why I want Linux (amoung other reasons). |
#12
Re: Using Linux?
If you don't have the connection speed (or the patience, or require support from a single place; the vendor) then a boxed software version is probably worth looking at. |
| Linux | SteveC116 | 3D Animation and Competition | 22 | 25-03-2004 15:07 |
| Linux: steps to program fullsize RC robot | rwaliany | Programming | 31 | 14-02-2004 14:45 |
| Linux And Windows XP | Raven_Writer | Chit-Chat | 4 | 06-08-2003 18:53 |
| RoboEmu for Linux (PBASIC emulator) | rbayer | Programming | 5 | 21-11-2002 21:08 |
| Linux file extensions | rbayer | CD Forum Support | 5 | 14-11-2002 23:04 |
