Go to Post Copies gonna copy. - Arpan [more]
Unread 15-06-2004, 17:05
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Question VB6: Joystick help!
I'm using the Joystick API to get info on joysticks. The problem is that even though it claims to have a joystick, it says that it has no axis. Which indeed would seem to be the case: it seems to have a joystick w/o any axis or buttons. I have one plugged in, and it seems to work. I attached the module in question. Help?
They idea is that you call InitJoystick(), then you call GetPos() to update X, Y, and Z.
Problems hooking up a joystick to edubot Salik Syed Programming 2 24-03-2004 23:56
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
