Go to Post what is integration if not a compromise? - Kris Verdeyen [more]
Unread 23-06-2004, 19:49
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
Using the TTL and program port
Now I know the gut reaction of all you good, community-minded CD users is to point me to a search of the forums for this information, but I have already done that. After spending an hour or two looking on several websites, I could not find a complete explanation of how the TTL (and program) port works and how to use it. I understand the topic might be too big for a single resource to cover it, but even an introduction is lacking. Some of the things I'd like to know are
  • what does the protocol specify (i understand it is very loose)
  • pin out chart (specific to RC/Robovation)
  • What do the functions in usart.h actually do
  • a (well) documented example of its use
Of course, you can help the whole community out by recording this information in a FIRSTwiki article about the TTL port. Thanks.
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Having trouble with TTL port Gene F Programming 12 10-02-2004 15:23
TTL pins Dave... Control System 3 07-02-2004 23:59
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
