Go to Post Code doesn't break. It reacts exactly the same time every time. When something new happens that never happened before, it's because the mechanicals, electricals or drivers gave the code some new stimulus that wasn't tested before. - GaryVoshol [more]
Go Back   Chief Delphi > Other > FIRST-related Organizations
Unread 07-07-2004, 15:47
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
[FVG]: OI or RC as control input
Several times I have proposed using the OI/RC as the control input. Here's my write up on it.
There are 2 ways to do this: use the dashboard port or write a program for the RC.
  • Dashboard
    Use the OI (with or w/o RC) as 4 game ports. you hook up the original controls & the dashboard and you're all set!
    PROS:
    • Lots of game ports.
    • original controls work
    CONS:
    • May not work w/o RC
    • Not everyone has an OI
    • Not everyone has an RS-232 port
  • RC
    You load a program to the RC and hook up the prog port to your PC. You turn it on and it should work fine!
    PROS:
    • Wireless!
    • almost garenteed to work
    • Can be made to work with previous years
    CONS:
    • May require the big batt (see below)
    • Not everyone has an OI/RC
POWER
There are a couple of things we could do for power of the RC/OI:
  • Use the original equipment (safest, heaviest?)
  • Make an AC adaptor for the RC (most cords)
  • Make custom battery backs (need to replace batteries)
I guess that is more of an user problem, not our problem.
I've attached a version of the code for the RC. (79.5 KB)
Unread 07-07-2004, 19:42
Mike Ciance Mike Ciance is offline
FRC #0025 (Raider Robotix)
Mike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant future
Send a message via AIM to Mike Ciance
Re: [FVG]: OI or RC as control input
we could include this as a deluxe feature, but we obviously need to have a keyboard/mouse configuration also.
Unread 07-07-2004, 20:17
AKA: Jamie Bliss
In addition. I'm advocating complete config.
Unread 08-07-2004, 05:56
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Ok, ok, we'll do it for you...
But, you get to be in charge of that...
[FVG]: Controls Round 1 Mike Ciance FIRST-related Organizations 10 05-07-2004 16:00
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
goals: how much control? Pat Sarmiento Rules/Strategy 2 18-01-2002 19:10
