| View Poll Results: What's your SAT Scores? (verbal & math combined) | |||
| 1600 |
2 | 3.28% |
| 1500-1599 |
8 | 13.11% |
| 1400-1499 |
15 | 24.59% |
| 1300-1399 |
11 | 18.03% |
| 1200-1299 |
14 | 22.95% |
| 1100-1199 |
7 | 11.48% |
| 1000-1099 |
3 | 4.92% |
| 900-999 |
1 | 1.64% |
| 800-899 |
0 | 0% |
| 799 or lower |
0 | 0% |
| Voters: 61. You may not vote on this poll | |||
What was your SAT score (poll, don't have to post)
Just wanted to see what the brain trust at CD is like on the SATs. Now, I know the thing has changed over the years (and will next) so this won't be a really good indicator, but you know.
Re: What was your SAT score (poll, don't have to post)
Well not an SAT but on my PSAT i got somewhere around 1350ish, from what i knew of how to figure out the raw scores to actual scores, and now i dont remember the raws, so i cant actually tell.
1220 this time around. However, with Purdue's "best math and best verbal" score system, I have a 1250 with them - Take my 640 math from the first test, and my 610 verbal from 2nd test, combine, voila.
I got an 1120 on the SAT I when I took it at the end of my Junior year.
I got a 31 on the ACT, which is the equivalent of a 1400, two weeks after the SAT I. I STRONGLY urge anyone with low SAT scores, and really, anyone in general, to try the ACT. I found it to be much, much easier. Cory |
Havnt taken my SATs yet, but I scored well on my PSATs. Pity Ill prolly have to take the new SATs(with the essay, and out of 2400 instead of 1600).
this yr i scored a 1250 (700 on math, and 550 on verbal) yeah i really need to boost up my vocab. but i'm only a freshman... or going to be a sophmore, so i still have time
hey do you guys have any tips when it comes to taking the SATs? my only advice is guess 2 times per section... those guesses dont include the ones where you do trial of elimination. that n have a clear mind ![]() |
Never took it...
1300 on my first try, but i'm aiming for at least a 1350 next time - scholarship reasons.
some advice for everybody: VOCAB IS KEY FOR THE VERBAL!!!!! the verbal section is fairly easy if you know all the words your dealing with. the problem is, you often don't. studay vocab, it will make a huge difference. also, TAKE A PRIVATE TUTORING COURSE!!!!! i went to Huntington Learning Center and boosted my score by a ton. when i first took the SAT there for practice i only got an 1180, and when i took it for real i had improved 120 points!!! don't take a group lesson, you need to work on the areas where you need to improve. private tutoring will send your score shooting up. |
#10
I think the real thing to keep in mind - and most colleges are nowadays (unless we're talking private, ivy league, etc.) is that the SAT is a 3 1/2 hour test given on one day, and somehow it's supposed to measure your reasoning ability. The current SAT is becoming less and less credible, so that's why it's being changed - however, I don't see how an additional writing section will change this.
The SAT is really different for everyone, and many times you're not even trying to find the correct answer, but their (ETS's) correct answer. That's why I don't like the SAT. |
#11
I took it at the end of my Sophomore year and I received a 1310. However, I will be re-taking it in October, and I'm thinking I'll get at least a 1400.
| ChiefDelphi Forums Community Bulletin | Brandon Martus | CD Forum Support | 0 | 30-03-2003 23:00 |
| ChiefDelphi Forums Community Bulletin | Brandon Martus | CD Forum Support | 0 | 12-01-2003 22:19 |
| ChiefDelphi Forums Community Bulletin | Brandon Martus | CD Forum Support | 0 | 05-01-2003 22:04 |
| ChiefDelphi Forums Community Bulletin | Brandon Martus | CD Forum Support | 0 | 05-05-2002 22:07 |
| ChiefDelphi Forums Community Bulletin | Brandon Martus | CD Forum Support | 0 | 04-02-2002 00:39 |
