Go to Post :D NASCAR is way harder than we thought. - SL8 [more]
Unread 19-07-2004, 15:37
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
White Paper Discuss: IRI Results
Thread created automatically to discuss a document in the White Papers.
IRI Results by DougHogg
Unread 19-07-2004, 16:05
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
Team Role: Coach
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Re: White Paper Discuss: IRI Results
I had trouble uploading this file as a text file, so I wound up uploading it in spreadsheet format. You should be able to open it with Excel, Filemaker on Mac or PC (which automatically converts it to a database), Access, Microsoft Works, etc.
The first record (first row) contains the field names. However for some reason, when I converted the file to a spreadsheet, any text data was trimmed, so "Row#" became " R o" (with weird invisible characters between the "R" and "o".
The data for each match is repeated 4 times, once for each team in that match. That way, you can load the file into a database, sort it by team#, and find the total scores and QP's for each team.
Included in each record (row) is the remainder of the data for that match: blueteam#1, blueteam#2, blue score, blueQP's, redteam#1, etc. There is also a "Notes" field which gives data on which matches were "mentor" matches. The above format results in duplicated data, but I find it nice to be able to search one field for a team to find all their matches and then see all their partners and opponents on the screen for each match. I basically merged two different files into one. The first file contained match data (blue team#1, BlueTeam#2, BlueScore, BlueQP, etc) and the second file contained the match scores by team# (Team#, Score, QP).
A couple of teams weren't able to make it to IRI, so other teams stood in for them. The "Notes" field mentions several teams that stood in, but I am missing most of them.
The field names (column names) from left to right were: Row#, Match#, Team#, Score, QP, Partner, BlueTeam#1, BlueTeam#2, BlueScore, BlueQP, RedTeam#1, RedTeam#2, RedScore, RedQP, and Notes.
To put the file back in its original order, sort it by the first field which is "Row#" (which should be made a number field if importing the file into a database).
To see just the qualifying rounds, find Row#<445.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 19-07-2004, 16:15
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I saved this as .xls instead of .txt and it opened fine in Excel.
Take care!
Andy Brockway
Team 716, The Who'sCTEKS
White Paper Discuss: Users Guide to Autodesk Inventor CD47-Bot Extra Discussion 2 18-12-2006 17:45
White Paper Discuss: SimSwerve Omnidirectional Drive System CD47-Bot Extra Discussion 11 14-06-2004 10:02
White Paper Discuss: 2004 IRI Description and Details CD47-Bot Extra Discussion 1 12-05-2004 16:03
White Paper Discuss: Championship 20004 results for all divisions CD47-Bot Extra Discussion 1 23-04-2004 02:05
White Paper Discuss: Cyber Blue 234 Design Review Process 2004 CD47-Bot Extra Discussion 1 18-03-2004 22:51
