Go to Post FIRST is not about a robot competition . . there just happens to be one at every FIRST event. - Stuart [more]
  #16   Spotlight this post!
Unread 01-08-2004, 23:05
KarenH's Avatar
KarenH KarenH is offline
Mrs. ChrisH
FRC #0330 (Beach 'Bots)
Team Role: Parent
KarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond repute
Re: Gas powered engine horsepower equivalent to electrical motor horsepower?
Originally Posted by Al Skierkiewicz
Elgin,
...In the operation you are considering, gas power is easier to implement and that is why most designs use that type of engine.... All things considered, the gas powered approach is still the best over all design.
If you want to take an approach looking at the overall design, however, there are several other factors you should consider:
If you should ever want to take the machine on an airplane, let's say to go visit friends or to go to some kind of show or competition or something, no airline will ever let you take a gas-powered device with you. Even if you empty the fuel tank, the residual fuel and fumes represent a hazard that is completely unacceptable to the airlines and federal safety requirements.
On the other hand, if you're in a place with no electricity, you'd be unable to recharge.
Electric motors are usually much quieter than gas motors--a factor your neighbors will appreciate.
Transporting, storing and using gasoline has certain health and safety risks involving toxicity, flammability, and pollution (though if you already have small gas-powered devices such as a lawnmower, you've already taken that step). Of course, batteries have similar problems. Which set of risks would be of greater concern to you?
Gas engines are mechanically more complex than electric, and require more complex maintenance.
You also need to figure out how the control system will work with your setup.
In summary, there are the initial design considerations (What is the most feasible design for your needs?), but there are also the long-term usage considerations (which design will be the easiest to live with over the long haul?).
By the way, I've seen a guy zipping along the Strand in Manhattan Beach on a gas-powered SKATEBOARD. He has a hand-held control (probably the throttle) connected to the board by some type of cable. The little fuel tank is located behind the rear truck. I'm not sure such a device is legal on the Strand, though...
Karen Husmann
Ex Robo-widow
  #17   Spotlight this post!
Unread 01-08-2004, 23:24
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
wow! didn't the kawabunga(spell check???) turtles have something like that? or was it wind powered... i kinda remember a huge fan on the back..... hehe.
  #18   Spotlight this post!
Unread 03-08-2004, 08:42
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Gas powered skateboards go back into the sixties. You see them in several movies of the period. I think I remember one in "On Any Sunday" a doc with Steve McQueen. I have heard that many places outlawed them since they do not have deadman switches or brakes.
Al
WB9UVJ
www.wildstang.org
________________________
  #19   Spotlight this post!
Unread 15-08-2004, 12:36
aaronbr28040's Avatar
aaronbr28040 aaronbr28040 is offline
AKA: Aaron Bradshaw
#0900 (Team Infinity)
aaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really nice
Send a message via AIM to aaronbr28040
Talking about gas powered motors...I guess you will probably use a small Briggs and Stratton Engine. The horsepower ratings that you see are for the engine at 3600 RPM's. These motors will run, if in good shape with enough oil, at 3600 RPM constantly. By replacing the rod, using a shorter piston, twisting the cam, and using a 3HP flywheel and a few other assorted things you can get a 5HP Briggs motor to turn 9200 RPM running methyl alcohol racing fuel. These motors are what are run on the racing gokarts.
Anyways....thats for 4 cycle motors. You might consider using a 2 cycle weedeater motor. They can turn a lot of RPM's and I have seen small kids gokarts, minibikes etc powered by them. They are also really hard to blow as long as you keep oil in the gas. The connecting rod rides on the small crankshaft in these motors on bearings.
If you use a gas powered motor you will also need a centrifugal clutch of some type since you cant just turn it on and off like an elecdtrical motor.
-Aaron
@North Carolina State University
Team 900
North Carolina School of Science and Mathematics
AIM:aaronbr28040
  #20   Spotlight this post!
Unread 15-08-2004, 14:59
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Rookie Year: 2000
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
Originally Posted by greencactus3
as long as you keep the block from overheating and have decent lubrication( i guess thats part of the overheating prevention) and dont run out of gas, quite a long time.... for example, car engine's peak output rpm is around 4000~6000 rpm. i think... not diesel, gasoline... and not rotary engines either, which tend to have lower rpm peak power. car engine's redlines are a bit higher than the peak, so well,,, im confusing myself again.... help?
Heh - now is when I inject my 2 cents worth...
A car engine's peak HP/Torque can happen low or high (depends on the application) For rock crawling and stuff that you need the most of the power lower in the band - you just change the timing/cam. I have seen engines with the most torque at about 2,000 RPMs. Now for horse power - yes you will typically need to go higher. I think that the lowest i have seen HP is at about 3,100 RPM (agian - these are for any decent hp/torque 200+ in each catagory) But for Racing applications - you wish to have a split. Torque in the low end and HP in the higher end.
For this application I'd personally like to see a diesel engine. The RPMs are kept much lower, and the torque is needed here (and lots of it.) Gas is better for speed - but diesel is best for getting off the line/heavy loads.
And for the Peak HP/Torque curve and the redline - rember you have gears in your vehicle. When you shift at your redline - you idealy will be right in the middle of your power band (from the taller gearset) - so you get the most pulling power when you shift.
That rug really tied the room together...
  #21   Spotlight this post!
Unread 17-08-2004, 23:11
kacz100 kacz100 is offline
Battle Cattle!
#1466 (Webb Robotics)
kacz100 is on a distinguished road
Send a message via AIM to kacz100 Send a message via Yahoo to kacz100
MMMM propane injection...
Kacz
Team #40 Alumni 1999 - 2002
Team #885 College Student/Mentor 2003
Team #1466 College Student/Mentor 2004
  #22   Spotlight this post!
Unread 18-08-2004, 17:48
AKA: Maher Attallah
Rookie Year: 2000
Propane > NOS for this application.
Personally i'd choose diesels now a days for how much more efficent they are over gasoline engines.
Turbo Cummins diesel 5.9 in a Dodge ram 3500 dualie...:drool:
(Durmaxs are junk.)
  #23   Spotlight this post!
Unread 18-08-2004, 18:39
Battle Cattle!
(Durmaxs are junk.)
My dad has the 7.3L Ford diesel..20mph+ after his turbo problem he hasn't had any problems...but Fords are cheap, we need to put some extra springs in the front end because the frontend went down 2 inches...
Diesels rule and gas drools (at the sight of a diesel engine)
Kacz
  #24   Spotlight this post!
Unread 18-08-2004, 19:09
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
Well while were on the topic of gasoline engines there was an article in this month's Popular Science about an Indian mechanic who created a gasoline engine capable of running a car without a transmission by only using a dremel tool. Now we just need to see if this modification is useful in more modern cars.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
  #25   Spotlight this post!
Unread 18-08-2004, 19:15
AKA: Maher Attallah
Rookie Year: 2000
I agree for the most part - but Diesels have their place just as gas does.
I'd just like to see a lot more american/imported to america vehicles have Diesel engines. That's the main problem with the MPG of the bigger vehicles (suv, truck, ect...) - you need more torque to make that heaver load go - more power = more gas - and gas works at a lower compression ratio compared to diesel (gas runs at about 8.5-9.0 : 1 on most gas, diesels run anywhere from 14.0 - 22.0 :1 compression ratios.) And diesels can run much, much leaner than a gas engine can. And you can run your diesel engine off of Vegatable oil!! (http://www.greseal.com)
  #26   Spotlight this post!
Unread 18-08-2004, 19:23
Adam Y.'s Avatar
Adam Y.
no team (?????)
You can't run it without modifications. If you do you'll destroy all the rubber gaskets. Also if I remeber correctly running an diesel engine off of vegatable creates more emissions than running it off of regular diesel fuel.
  #27   Spotlight this post!
Unread 19-08-2004, 08:41
AKA: Maher Attallah
Rookie Year: 2000
For the gaskets - if you pay attention to the site - first off you need to start it with the regular diesel. Secondly that was the orignal point for Diesel engines was to run off of peanut oil. Third the site claims that it has more lubercation properties than regular Diesel fuels. They are even running a Mack Semi on this stuff hauling a trailer (the huge 14+ Liter Straight Six engine)!
I'd personally run the vegatable oil in my vehicle...
(Sorry - Here is the right site - http://www.greasel.com)
  #28   Spotlight this post!
Unread 19-08-2004, 09:00
suneel112 suneel112 is offline
AKA: the angry designer on 461
#0461 (Westside Boiler Invasion)
Team Role: Student
suneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud of
Send a message via AIM to suneel112
Is the ONLY reason that gas is better than electric motors because it is easier to carry around gas power? If there was an easier and more efficient (more energy per weight or something) way to carry around electricity, would electric motors replace gas? Maybe one idea is to have a nickel-metal hydride fuel cell to power the electric motor. That may last a while, and you can recharge it. I am looking into an idea like that myself. The distance from my school to the Purdue math building is about 1 mile, and it will be tough when it starts snowing. There is also no parking anywhere near the math building (C Permit). So maybe I can make a NiMH Fuel Cell mobile that folds up like a bike and ride it to math. Or maybe not...
I'm back like the greatest, from a four year hiatus,
Haters cry later, I'm just getting my paper.
  #29   Spotlight this post!
Unread 19-08-2004, 10:26
AKA: Maher Attallah
Rookie Year: 2000
The problems with electric is the power source. It can be big, clunky, heavy, etc... Also - the Size of the motor can be a problem too. Sure - you can get a 72 Volt system or what ever - but than your power source won't last long at all. That is why for most purpoces gas will be used for transporting something or use the electric motor for the low end and the gas motor for the upper (coasting) end...
  #30   Spotlight this post!
Unread 19-08-2004, 11:16
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
unfortunately, electricity has nothing when you compare its power density to gas, I wrote a lot going into details, then my browser crashed, so, I'm just gonna leave it at that.
"Jack of all trades, master of none, though offtimes better than master of one".
