Go to Post If that due diligence shows that a real need for action exists, *then* grab the pitchforks, and light the torches. - gblake [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 10-08-2004, 17:01
Michael Leicht's Avatar
Michael Leicht Michael Leicht is offline
Drive Coach
FRC #1403 (Cougar Robotics)
Michael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond repute
gears
Can someone help me. I took a blue print of a gearbox from the white pages and making it in inventor and i came to the part of gears and i was wondering if anyone can help me with these gear or knows of a place were i can download the gears.
Dual-Motor, Dual-Speed Robot Transmission
the gears are:
Speed change gear 20 pitch, 20° pressure angle, 1/2” face width, 25 tooth steel gear B-GSS-2025 Small Parts
Bosch pitch change gear 0.7 module, 20° pressure angle, 1/2” face width, 55 tooth steel gear MSG25-55 PIC Designs
Torque gear A 20 pitch, 20° pressure angle, 1/2” face width, 14 tooth steel gear B-GSS-2014 Small Parts
Torque gear B 20 pitch, 20° pressure angle, 1/2” face width, 50 tooth steel gear B-GSS-2050 Small Parts
Torque gear C 20 pitch, 20° pressure angle, 1/2” face width, 25 tooth steel gear B-GSS-2025 Small Parts
Torque gear D 20 pitch, 20° pressure angle, 1/2” face width, 40 tooth steel gear B-GSS-2040 Small Parts
High speed output gear 20 pitch, 20° pressure angle, 1/2” face width, 35 tooth steel gear B-GSS-2035 Small Parts
Shifting gear high speed 20 pitch, 20° pressure angle, 40 tooth steel (303) gear stock A 1C29-Y20040 Stock Drive Products
Low speed output gear 20 pitch, 20° pressure angle, 1/2” face width, 15 tooth steel gear B-GSS-2015 Small Parts
Shifting gear low speed 20 pitch, 20° pressure angle, 1/2” face width, 60 tooth steel gear B-GSS-2060 Small Parts
Team 303 (2003-2007)-Student-Won FIRST Scholarship to Daniel Webster College
Team 42 (2007-2008)-College Mentor
Team 2342(2008-2011)-College Mentor
Team 1403 (2011- )- Mentor
Looking for gears from BostonGear in Inventor.. geo Inventor 6 05-08-2004 10:07
Looking for KOP Helical Gears ChuckDickerson Kit & Additional Hardware 1 21-07-2004 15:39
What type of steel are gears commonly made from? Matt Adams Technical Discussion 5 02-01-2004 23:19
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
