Go to Post My father taught me long ago that how we respond to adversity is what defines us as human beings. Let's all keep this definition in mind as we move forward to change a culture. - Rich Kressly [more]
Unread 12-08-2004, 11:46
gomez6760 gomez6760 is offline
gomez6760 has a little shameless behaviour in the past
disabling a button
can someone tell me how to disable or enable a button depending on the name of the button that I have stored in my database but without doing if's in my procedure. What I want is the following:
Example I have 10 buttons in a form. The name of my buttons are stored in my database. But when my database sends back my result (example only 4 names) I cannot put the name of the button because delphi does not know that that is an object, it says that it is a string which is right because you store the name of the button as a string in your database.
I do not want to do a loop an 10 buttons and do if name is equal to btn.name
I would like to do a proedure only with the results
Any suggestions ? Thank you
Unread 12-08-2004, 11:54
Billfred's Avatar
Billfred Billfred is offline
Re: disabling a button
I probably should point you to this sticky. I'm afraid that Chief Delphi is a web site of a FIRST Robotics team sponsored by Delphi, not a site covering Delphi programming.
There are a few folks here who may know Delphi programming, but your odds would probably be better at a Delphi programming forum.
Thanks for stopping by, either way! (Like robots? We've got plenty.)
--Billfred, aka "I am not a moderator, but I am JVN."
(sorry, forum in-joke. couldn't resist)
Button wishlist 2004 natonal's Tytus Gerrish Championship Event 19 16-04-2004 00:53
Button Programing BobcatProgramer Programming 6 25-02-2004 16:43
which button machine do you use and do you like it? KenWittlief General Forum 10 16-10-2003 00:01
Select button and user mode n[ate]vw Programming 2 20-01-2003 16:33
Just wondering about a button from nats... archiver 2001 1 24-06-2002 04:07
