Go to Post What makes a man is not the mistakes, but the actions that follow. Andy B. - Andy Baker [more]
Go Back   Chief Delphi > Other > FIRST Lego League > Lego Mindstorm Discussion
  #16   Spotlight this post!
Unread 25-08-2004, 09:21
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Re: Dead RCX..
Originally Posted by greencactus3
hmm. the only thing is, that it works with the small programs.. if it didnt work at all, itll be somewhat more explainable.
i havent configured the lego software, i dont think,. is there a way to?
The small program thing actually makes sense though. The COM tower will just shutdown if it isn't kept alive (I thought that the mere act of sending data to it would do that, but maybe not.), so after the first 5 seconds of transfer, it gets turned off. If it's a small program, it gets sent in that time. Otherwise, it gets interrupted and the RCX erases what it did have, because there's no point in keeping the incomplete program.
  #17   Spotlight this post!
Unread 25-08-2004, 09:35
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Re: Dead RCX..
I just talked to greencactus3 on AIM.
It seems also to me that there is a problem not being switched to Serial Tower.
He did clear out the RCX of all programs using the Reformat thing.
If it takes little programs there can't be a problem with the USB to Serial converter or not being on the right COM port
I do not have the software in front of me could someone tell him how to switch to Serial using RIS 1.5??
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
  #18   Spotlight this post!
Unread 25-08-2004, 14:39
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: Dead RCX..
The serial tower stays on for 3 seconds after the last transmit, during which it can recieve messages. It is woken up when you send data. There is a hack to make it stay on when the RTS pin is on.
In RIS 2, it's in the options screen, or when you install the software. If it isn't there and the help file won't tell you, it might not support USB (Though the drivers for the COM/USB thing should set up a virtual COM port).
Try using CommTest from my site. (http://endeavour.zapto.org/astro73/programs/) The current version has some bugs, I'll tell you in it's fixed.
Send anything out the COM ports (try each one) and look for the green light.
  #19   Spotlight this post!
Unread 25-08-2004, 15:11
Programming User
Re: Dead RCX..
Isn't RIS 1.5 always set to use the serial? It doesn't support USB as far as I know.
  #20   Spotlight this post!
Unread 31-05-2005, 00:48
robbie thompson robbie thompson is offline
robbie thompson is an unknown quantity at this point
Re: Dead RCX..
Originally Posted by Mike Ciance
anybody have problems with RCXs that don't respond to IR, but still turn on? i have 3 of those currently in my posession.
anyway, try to contact lego about it. they never responded to me, but maybe you will have better luck.
hey mike i have the same problem....i too have emailed LEGO and they havent replied ,,,just wondering if you have had any luck recently
RCX Programming Guyute FIRST Lego League 10 23-08-2004 16:25
Using an FRC with the RCX? Astronouth7303 Programming 21 15-04-2004 14:14
What to do with autonomous Rickertsen2 Programming 48 17-02-2004 16:22
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
dead robot in the finals? srawls Rules/Strategy 2 24-03-2002 14:44
