Go to Post FIRST is like Starbucks coffee, it's addicting and you just can't seem to get away from it... - Beth Sweet [more]
Unread 24-08-2004, 17:08
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
CNC Mill Help
Ok our team has had a mini CNC mill lying aroung for a while, but nobody has touched it because we havn't had time to learn it. First off is this thing even capable of machining Aluminum? What bits etc do we need? Any advice at all would be appreciated. I know almost nothing.
ps: We have mastercam and i am learning it.
1139 Alumni
Unread 24-08-2004, 17:38
cmaccoy's Avatar
cmaccoy cmaccoy is offline
FRC #0173 (R.A.G.E.)
Team Role: Student
cmaccoy is on a distinguished road
Send a message via AIM to cmaccoy Send a message via Yahoo to cmaccoy
Re: CNC Mill Help
Ok, i'm guessing it is a light milling machine. aka a very small milling machine. They usually can cut through most metals easily (cutting small amounts at a time). The one in the link looks like you have to link it with a computer. Is it linked with one now?
~cmaccoy
F.I.R.S.T. My anti-drug
Unread 24-08-2004, 17:58
Umm Errr...
Re: CNC Mill Help
Yes it is linked with a computer. The computer has both mastercam and some sort of software for milling things from nc files.
When you say that this thing can machne most metals do you mean just soft metals like aluminum and brass or harder metals such as mild steels as well?
1139 Alumni
Unread 24-08-2004, 18:42
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Re: CNC Mill Help
i have seen that machine before and it is not capable of cutting metals it is designed for cutting plastics and snythec materials. it is mainly a teaching tool but you could make some awsome hand outs with it...
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 24-08-2004, 19:15
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Rookie Year: 1999
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Re: CNC Mill Help
The woodshop our team is based out of has an identical machine. It's hooked to a Windows based PC like that one. The motor isn't powerful enough for steel. The only thing we use it for is engraving plastics and brass. We basically make signs or name tags with it as that is all it's basically good for. Like mentioned above it's main purpose is a teaching tool and not manufacturing parts.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 24-08-2004, 19:22
Umm Errr...
Re: CNC Mill Help
I know its meant for education and plastics. Is it capable of doing even light machining of aluminum. Right now the only means of getting parts made that need to be milled is for us to goto our sponsors. This is time consuming and a pain.
1139 Alumni
Unread 24-08-2004, 19:55
AKA: Jason Hartmann
Rookie Year: 1999
Re: CNC Mill Help
I don't know the specs of the one at our woodshop off hand but if they are similar to the one you're looking at for all intents and purposes I'll have to say "No". While it may be capable of machining by taking small passes at a time I think it's service life will be greatly reduced. I'd rather not see you're team be disappointed when the unit fails in the middle of build season.
Now I don't know you're teams position but I feel you'd be better off purchasing a new or used mill like a Bridgeport. This suggestion should eliminate or reduce you're team's dependence on outside help for machining. Several bonuses of a mill is a wider selection of bits and attachments than you would have for that mini CNC mill. You would also be able to remove more material in each pass. This is if you have the funds and the space to put a machine like this. You might even be able to ask local businesses and they might even donate one as they upgrade to newer machines.
This may not be what you wanted to hear but my gut feeling is that the mini CNC mill will not hold up to what you want it for.
$.02
Unread 24-08-2004, 21:56
Umm Errr...
Re: CNC Mill Help
Ideally a real AKA: Bridgeport style is our goal. Unfortunately we don't have $5000 to spare for somethign like this new. Depending on how fundraising this year goes this year though it might be possible for us to get a used mill. Until then i guess we will be outsourcing.
Ok heres a question. Out budget is rather limited. What are the disadvantages of a "Mill/Drill"? They are considerably cheaper. It looks as if we can get a new "Mill/drill" with powerfeed and DRO as well as an assortment of accessories for the price of a baseline mill with almost nothing. Even if we do get a real mill we will still leave complex/precision parts to our sponsors because none of us would be skilled enough to make these parts even with the right tools. Would a "Mill/drill" be adequite for basic parts (IE: various mounting adapters, simple mechanisms etc.) ?
1139 Alumni
Unread 25-08-2004, 00:59
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: CNC Mill Help
A general rule that I remember hearing is that you should plan to spend as much on tooling as you do on the machine tool. It aint gonna do you much good if you have a nice and shiny mill, but nothing to go with it.
I've seen ads for used bridgeports from machine shops in my area for like $2000-2500, which seems pretty good, but I'm no expert, so who knows what you might be getting when you buy used.
$0.02 Cory
2001-2004: Team 100
2006-Present: Team 254
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Help - G-Code Circular Motion for CNC Milling sanddrag Technical Discussion 15 18-08-2004 23:00
To CNC? Or not to CNC? phrontist General Forum 21 26-03-2004 13:45
Haas CNC Mill Graph Function P-Dog Technical Discussion 9 13-03-2004 23:45
How hard is it to CNC this? sanddrag Technical Discussion 16 01-03-2004 08:47
