Go to Post Dance Dance Revolution is the only solution. That rhymed. I should not be on chief at this hour of the morning. >_< - Eugenia Gabrielov [more]
Unread 30-08-2004, 18:10
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
USART ContRX vs SingRX
Does anybody know what this setting does? It doesn't seem to have any effect on anything. The only thing that i can think that it might do is change the behavior of what happens if a new byte is recieved before the register is cleared. The 18f8520 documentation is very little help on this.
1139 Alumni
Unread 30-08-2004, 19:07
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: USART ContRX vs SingRX
The SREN/CREN bits are only used if the USART is configured for synchronous operation. If you're using it for synchronous operation, then the CREN bit enables the continuous reception of Rx data (i.e., Rx data will be continuously received and dumped to the RCREG register). If it's your desire to only read one word at a time, you'd want to enable the SREN bit, which will allow the USART to receive only one word and then shutdown any further reception of data. The PIC18C Reference Manual has more information than the data sheet.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Last edited by Kevin Watson : 30-08-2004 at 19:53. Reason: Ugly grammatical error.
Unread 30-08-2004, 19:52
Umm Errr...
Originally Posted by Kevin Watson
The SREN/CREN bits are only used if the USART is configured for synchronous operation. If you're using it for synchronous operation, then the CREN bit enables the continuous reception of Rx data (i.e., Rx data will be continuously received and dumped to the RCREG register. If it's your desire to only read one word at a time, you'd want to enable the SREN bit, which will allow the USART to receive only one word and then shutdown any further reception of data. The PIC18C Reference Manual has more information than the data sheet.
-Kevin
Whoa thanks!!! I never even bothered reading that document. I looked at it once and assumed is was jsut a less specific version of the 18f8520 manual. There is alot of good stuff in there!!
1139 Alumni
EduBot and USART ports Dave... Programming 13 01-02-2004 00:02
