Go to Post Grease your gearboxes folks! Gears need grease, otherwise they kerplode. - s_forbes [more]
Unread 12-03-2002, 22:15
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Rookie Year: 1999
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
Multi Motor Drivettrains
Hey,
I saw some of the nicely done drive trains such as Woburn as the image posted by the Technokats in a different message. I was wondering how one could go about figuring out the gear ratios for connecting two different motors to a singular drive train. My thought was that find the ratio of RPM's and then match gears with the reverse ratio. Is that correct? For example the drill motor has 300RPM (not true) and the fisherprice motor has 100RPM, would you put a gear ration of 1:3 on the two motors, where the gear on the fisher price motor is 3 times greater than that on the drill motor?
Multi Drive Fun... Sachiel7 Technical Discussion 14 13-10-2003 01:06
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
Multi Subwoofer wiring - which amp to use? -- Help!!! Elgin Clock Chit-Chat 9 22-02-2003 20:07
multi rotational potentiometers jdawson Electrical 8 27-01-2003 08:12
