Go to Post Though, of course, if the old one you like is shot, then you can just beat your new one with a hammer until it works the way you want. - Kevin Sevcik [more]
Unread 07-09-2004, 18:55
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
Re: Calculating Wheel Size
Originally Posted by Max Lobovsky
How can suspension help with ground clearance? I understand how it helps handling bumps, but how does dampening vertical shock forces on your wheel give you greater ground clearance?
its simple.. its harder to bottom out or run on 3 wheels (if you're 4wd).
and you can bump over small obstacles which one without sus cannot
note- "4wd" is not in the spell check. neither is "sus" which i suppose really isnt a word, but oh well... not sure who to pm to so ill hope someone sees this and pms the correct person for me
Optical Sensors Used as Encoders? uvabrad825 Technical Discussion 22 03-05-2004 13:22
Quatro 4 wheel drive ufa_mike Control System 2 15-04-2004 02:30
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
