Go to Post I don't know how much of a safety factor chain manufacturers build into these ratings. I've got empirical evidence to demonstrate that it's not 5, however. - Tristan Lall [more]
Unread 29-04-2005, 08:43
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
FRC #0862 (Lightning Robotics)
Not2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond repute
Re: Best frame building material
[quote=cdr1122334455]I wise engineer once told me two things
1. There is no Best material, there are Right Materials.
2. Use the right application for whatever your material is.
QUOTE]
Very good - and true. Each application is unique.
862 has used plate aluminum, 80/20, welded aluminum tube, and "L" channel in various years. "L" channel (of various sizes) has worked the best for OUR team on the frame. But that's because we don't weld (for many reasons, even though we have MIG, TIG, and Arc welding equipment), we have a tendency to over tighten without spacer blocks (crushing box channel), and we don't use/have CNC Mills or Waterjet cutting (otherwise plate would be nice).
For us, material selection is based mostly on fabrication technique. Look around, see what other teams with similar resources use, and try it out over the summer.
Brian Graham
Unread 15-09-2004, 21:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Originally Posted by superbeano2004
I was curious on what is the best material for building a frame for a robot. Last year, we used 1" aluminum tubing and it did well but it was difficult to weld and it was not as strong. I see other teams using extrusion tubing and I was also curious on why extrusion so good. Thanks for your help!
Sorry but it looks like I beat you by about 2 years in starting this thread http://chiefdelphi.com/forums/showth...ssis+materials That's okay, it was buried anyhow. Brandon, perhaps we should merge? Or not?
Unread 17-09-2004, 21:31
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
1251 (my team) used extruded aluminum becuase it is stronger then that alumnium tubing your team used, however is it much heavier. so a good word of advice if you want to be light don't use extruded use the alumnium tubing. Extruded is good if your goin for robustness. The decision all depends on your design. Hope that helped.
Drew,
1251 THE TECH TIGERS
TECHNOLOGY FOR THE 21st CENTURY
Unread 17-09-2004, 22:32
RBrandy RBrandy is offline
AKA: Ryan
#0093 (NEW Apple Corps)
Rookie Year: 2000
RBrandy is a jewel in the roughRBrandy is a jewel in the roughRBrandy is a jewel in the rough
Send a message via AIM to RBrandy
Originally Posted by Rickertsen2
Vould you please elaborate on this a little bit? first off is does FRP come shaped like a panel? Or rods? tubes? what? I'm a little confused. It sounds to me liek you are saying it is a panel and you put in in the T-slot of unistrut?
First, let me answer this. We got square tubes. I believe it comes in a whole array of shapes and sizes. We took the unistrut, machined it down to a size that would nest tightly, but not too tightly, in the FRP. Then, we taped the hole, and screwed it in at a 90 degree angle to the instruct.
This is not frame related in the aspect you are asking about. Team 93, in addition to using the fiber glass (FRP), we also used a large 1/4 in. plate for mounting things, instead of using more pieces of 80/20. We used it to mount gear boxes, our battery, our electronics box, our programming, air compressor, etc. To make this plate strong we had one of our engineers brothers laser cut, then bend out 'ribs', if you will, to make sure it would not flex in any critical part. This part helped the robot meet the weight requirement and still stay robust.
I'm sure myself or Sean Schuff could conjure up some pictures of this plate so you can understand what I'm rambling about.
Team 93 Alumini
Unread 17-09-2004, 22:33
Rod's Avatar
Rod Rod is offline
Mentor
FRC #0662 (Rocky Mountain Robotics)
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
This year we plan to use the engineering teacher's head, it has got to be the hardest material known to man.
-Rod-
Team 662
Colorado Springs, CO
Unread 18-09-2004, 00:57
suneel112 suneel112 is offline
AKA: the angry designer on 461
#0461 (Westside Boiler Invasion)
Team Role: Student
suneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud of
Send a message via AIM to suneel112
Like Cyberblue, we used extrusion in the past (except for the "pre-me" robots - Rowdy 1 [2000] and Rowdy 2 [2001]). This summer, though, we replaced the frame with a welded box (1 in by 1 in or so) and it worked perfectly. It was 2 lbs lighter and we had weight to put on a pump (essential to the arm). Even though we didn't do great at IRI (because our arm broke in two places during the practice match - took 2 hours to fix, and the whole energy left in a battery issue), the frame was definitely a plus, and welded frames are what separate the men from the boys.
An example: Teams 66 and 279, the awesome teams we allied with at nats. Though 279 did use some extrusion in their arm, both 66 and 279 had welded frames (as far as I could see). They had very few limitations, except when the opposing robot would knock it over by entangling with the arm.
There are many more examples of this. Good one: WildStang this year, Beatty 71, and Las Guerrillas (469).
I'm back like the greatest, from a four year hiatus,
Haters cry later, I'm just getting my paper.
Unread 18-09-2004, 01:03
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
You don't even want me to list all the teams that have had great success with non welded frames.
2001-2004: Team 100
2006-Present: Team 254
Unread 18-09-2004, 01:05
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Umm. No. Fixing a welded frame after a breakage in the non-welded part at a regional where you really have no time for welding is what seperates them.
Welding = Bad.
I would rather take apart extrusion based frames and redo all the screws and fasteners than re-weld a part many times.
Anything that needs special tools and/or skills to maintain especially at a FIRST competition should be kept to a minimum, and welding is one of those special skills.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 18-09-2004, 01:14
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
i don;t know about you all but i bring my mig welder to all the regionals i go to ...infact i do
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 18-09-2004, 21:12
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
A good frame material I've heard of is carbon fiber board. You know.. the stuff motherboards are made out of. I'm guessing that if you make a basic chassis out of steel angle irons, and bolt on sheets of carbon fiber, it'll take a lot more damage than if you have polycarb side panels.
A related question:
I've seen how they make some airplanes, they get a big mold and use a special machine to lay carbon fiber all over it, making a shell. I've also heard they use this method for race cars. Of course I doubt many FIRST teams have access to NASCAR shops, but does anyone know how carbon fiber laying works? It would be cool to see a molded carbon fiber frame some day.
Unread 18-09-2004, 21:47
Ali Ahmed's Avatar
Ali Ahmed Ali Ahmed is offline
FRC #0004 (Team 4 ELEMENT)
Ali Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to behold
Team 598 used a carbon fiber shell with Kevlar for support. That is really smart because both materials are very strong and very light. We use 60601 T6 aluminum but thats only becuase we do a lot of welding onto the frame and its the best application we have found. Just the right strenght and its light enough.
Cheezy Poofs' Wheel Material evolution Technical Discussion 6 18-04-2004 23:11
Voltage on Frame Greg Electrical 31 02-03-2004 13:49
Rendering Tips Tyler Olds 3D Animation and Competition 27 16-10-2003 01:32
Building material archiver 2000 1 24-06-2002 00:10
frame material survey punarhero Technical Discussion 12 21-02-2002 06:47
