Go to Post "Insanity: doing the same thing over and over again and expecting different results." - Albert Einstein - Edward Debler [more]
Go Back   Chief Delphi > Other > Dean Kamen's Inventions
Unread 21-09-2004, 22:50
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Rookie Year: 2000
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Sterling Engine To be used to power spacecraft
I know Deano didnt invent the Sterling Engine but there is much talk about his use of it in his water purifier. Seems that nasa is using one to power a spacecraft check out the article here
http://www.newscientist.com/news/news.jsp?id=ns99996419
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 21-09-2004, 23:12
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Re: Sterling Engine To be used to power spacecraft
when i worked at the JHU applied physics lab i was on this project for a while.and it was very interesting stuff...specifically what we were working on was changing the range of temp differential to find best efficiency within the conditions of space, for the application that they would be members through the wall of the space station. 1 side would be inside utilizing the inside temperature of the station while the other is outboard using the cold of space...i wasn't on the project very long but i have always had the suspicion that they would pop up in this application in the future.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 22-09-2004, 11:19
suneel112 suneel112 is offline
AKA: the angry designer on 461
#0461 (Westside Boiler Invasion)
Team Role: Student
suneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud of
Send a message via AIM to suneel112
Is the stirling engine really better than the current power systems? For deep space, it may have an application, but close to earth, there is a great amount of solar energy for ready use.
I'm back like the greatest, from a four year hiatus,
Haters cry later, I'm just getting my paper.
Unread 22-09-2004, 11:43
it all depends on the effeceny of the system. the best solar pannels are at most 30-40 percent effecent, so if you can get a system that works at a greater effency then it would be worth it, even though there is quite alot of solar energy...
personally if it was me i would just make a really long extention cord and drop it to the earth so someone could plug in.....
Unread 22-09-2004, 12:57
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
This acoustic Stirling engine seems intended as an alternative to RTGs (Radioisotope Thermal Generators) rather than as a replacement for solar cells. Such power sources are typically used in "deep space" missions where solar power is quite a bit less intense than in our vicinity.
If your cord is sufficiently long, you don't even need to plug it in. You can just tap energy from Earth's magnetic field as you drag the cord through it.
Gas powered engine horsepower equivalent to electrical motor horsepower? Elgin Clock Motors 30 22-08-2004 20:44
Operator Interface power ISSUE kacz100 Technical Discussion 11 27-02-2004 13:46
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
