Go to Post you are going to gear that down right? Otherwise your robot will take about 10 minutes to reach its top speed of mach 2.6. - M. Hicken [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Q&A
Unread 22-09-2004, 21:25
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
[OCCRA]: more drive sprocket qs
Originally Posted by greencactus3
i have not been able to attend the workshops, and the guys from our team that did attend were not involved last year and therefore didnt note some things.
last year we attached a steel rod to the end or the drill transmission through a clamp thingy with the pins.. forgot what its called
this year, do we do the same thing?
the guys that attended were saying something about threading some sprockets and using the reverse screws to keep it on.. well, the only sprockets we have are the ones with the separate "hub" which we screw on to tighten against the rod... and the holes are not good for the end of the motor transmission...
so did we forget to recieve some special sprockets? or do we go the same way we did last year?
You are defiantly at a disadvantage not having attended the workshops. here is a quick review:
New this year are new drill motors. NO they do not mount to the shafts with a coupling like in the past. The sprockets are threaded and go on the end of the motor a special washer and left handed special screw is then used to secure the sprocket.
New this year is the way to mount the drive motors. You will need to fabricate a clamping system to use the boss on the drill motor as the clamping surface. We had two types of simple mounts at the workshops and pictures are posted.
Please read the rule over several times as these are but a few of the changes.
[/quote]
i have seen the pictures posted. thank you.. looks alot easier than last year
and you havent answered if we were to recieve some new "special" sprockets for this.. because we dont have any now... and does this mean we cant mount more than one sprocket to the motor? last year we had clamped two sprockets on.. is this no longer possible? and if we are to recieve "special" sprockets, how many teeth are they? so i can start thinking about ratios... and this washer you are talking about... is a plain one bought at home depot ok?
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
What is wrong with this code???? It won't Compile and I don't know why? Please Help CrashZero Programming 23 26-03-2004 09:44
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
