Go to Post Wait...you're supposed to have a driver? I guess I should have read past the Autonomous section in the manual :D - ASD20 [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Q&A
Unread 28-09-2004, 20:28
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
[OCCRA]: motor brush springs
new drill motor brush springs. after soldering the wires to the motor, and testing, i noticed it did not work.. why? because the brush spring had popped off and the brush was not pressed against the comm.
it was quite difficult to place the spring back because of the lack of "finger-space" is there an easy way to remove the endbell of the motor other than bending the part of the bell back? it would make access easier... the reason i want to have more access is, with rc car experience, i know stiffer brush springs will give more low end torque to the motor and softer springs will allow more higher rpms. will it be a bad idea to turn the brush springs, which are coiled, and extra 90 or 180 degrees (=stiffer springs)?
this kind of spring definitly seems easily adjustable without having to buy new ones. does this count as modification to the motor?
[OCCRA]: more drive sprocket qs greencactus3 OCCRA Q&A 1 24-09-2004 18:50
[OCCRA]: the motor sprockets greencactus3 OCCRA Q&A 1 22-09-2004 20:11
Constant Force Springs - Data Sheets? Ben Piecuch Kit & Additional Hardware 1 06-05-2004 19:00
springs hi_im_sean Technical Discussion 4 23-01-2003 19:05
springs CharlieWilken Technical Discussion 3 30-01-2002 19:39
