Go to Post I, being a Trekky myself, will really enjoy a Star Trek themed game if it turns out to be that. I will not enjoy programming the alcubierre warp drive. :D - AveryLevin. [more]
Unread 12-10-2004, 13:55
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
wun will become famous soon enough
Send a message via AIM to wun Send a message via MSN to wun
Shaft Encoders
My team has been trying to think of ways to make the drive system more accurate. One of the things we came up with is using shaft encoders to make sure the wheels would be spinning at the right speed (eg: instead of setting the PWM speed to drive, you use the joysticks to set the speed you want the wheel to be rotating at so if both joysticks are full forward, the robot will go straight, regardless of motor inconsistencies).
Has anyone had any luck with these? I have been doing some reading, but I would like to hear what other people have to say.
Help Microsoft stop piracy. Use Linux!
I have three gmail invitations, message me if you want one
Unread 12-10-2004, 14:18
Sean Schuff's Avatar
Sean Schuff Sean Schuff is offline
Year 18 in FRC!
FRC #0093 (N.E.W. Apple Corps)
Team Role: Teacher
Rookie Year: 2000
Sean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond repute
Re: Shaft Encoders
Our team used laser cut shaft encoders last year and they worked very well. We had rougly 200 slots cut in the entire 360 degree rotation - probably a little overkill but it did the job. And it kept our robot from drifting due to unmatched motors.
The #1 reason for having encoders - autonomous mode!
Good luck!
Sean
Every child. Every program. Everywhere.
Thanks Plexus Corp. for two decades of partnership and counting...your company gets it!!
www.nacteam93.com | Tesla Engineering Charter School
Unread 12-10-2004, 15:25
The Paco's Avatar
The Paco The Paco is offline
The dynasty has come to an end...
AKA: Goose
FRC #0048 (Delphi E.L.I.T.E.)
The Paco is a glorious beacon of lightThe Paco is a glorious beacon of lightThe Paco is a glorious beacon of lightThe Paco is a glorious beacon of lightThe Paco is a glorious beacon of lightThe Paco is a glorious beacon of light
Send a message via AIM to The Paco
Re: Shaft Encoders
for several years now we have used hall-effect shaft encoders tied directly to the output shaft of our gearbox and they have not failed us yet. we rely on them heavily in autonomous mode and during normal operation to make the robot drive straight.
a suggestion to make the robot drive straighter and eliminate any joystick inaccuracies may be to write in the code that if the sticks are within 5 or so counts of each other the same output is sent to the speed controllers. PM me if you would like any more details. id be more than happy to help!
If you tell people where to go, but not how to get there, you'll be amazed at the results.
- George Patton
"Quenching your thirst for FIRST"
Buckeye Regional Chairman's Award - '05 '06
Safety Award - '05 Pittsburgh
Website Award - '05 Buckeye
Imagery Award - '05 Buckeye
Sportsmanship Award - '05 GTR
Regional Finalists - '05 GTR
Unread 12-10-2004, 16:40
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: Shaft Encoders
I wrote some example encoder interface code that might be of interest. You can find it here: http://kevin.org/frc.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Using Digi-Key Shaft Encoders D.Viddy Programming 45 02-01-2005 20:11
Using Shaft Encoders D.Viddy Programming 7 14-12-2004 18:27
Problem with 5/8 in. shaft in this years kit echos Kit & Additional Hardware 5 14-01-2004 21:21
Who used wheel encoders CyberWolf_22 Technical Discussion 12 04-05-2003 15:37
Where to get shaft encoders D.Viddy Programming 12 17-01-2003 09:38
