Go to Post I like the way you are saving weight by cutting out the center of the speed controllers. - jcatt [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Q&A
Unread 18-10-2004, 20:28
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
[OCCRA]: one ways
are we allowed to have more than one pneumatic one way (check) valve in our pneumatic circuit? i know we need one right after our compressor, but we would like to use another one after the tank and ysplitter, and before a solenoid. the reason we would like to do this is, (for example: not exactly as this but same principle) when we have a spring retract cylinder extended, there is 60psi pushing out the rod.. when we use another cylinder which uses air split with a y, the air(pressure) slightly drops from the spring retract cylinder..and we'd like to keep the pressure in that cylinder constant. of course eventually the compressor will build up pressure in both cyliders eventually, but we dont even want a slight change until we activate the solenoid...
so basically what i want to do is
compressor
one way valve(check valve)
60psi regulator
tanks
y-splitter(fitting)
check valve.........solenoid
solenoid....................cylinder
[OCCRA]: [OCCRA] drill transmission greencactus3 OCCRA Q&A 1 11-10-2004 19:31
[OCCRA]: [OCCRA] LEDs greencactus3 OCCRA Q&A 1 11-10-2004 19:30
Looking for ways to incorporate Mt. Dew (aka - F.I.R.S.T. Fuel) into food recipes! Elgin Clock Chit-Chat 27 28-01-2003 11:09
Does any body know any good ways of doing this archiver 2001 0 24-06-2002 00:27
Does any body know any good ways of doing this archiver 2001 2 24-06-2002 00:27
