How to find the moment of an arm
Our team is working on a 5 foot arm made out of PVC pipe in a scissor lift configuration. The motor needs to be mounted at the beginning of the 5 feet. We are trying to find out how much weight we need to place behind the arm to counter balance the 5 feet of PVC. The back end needs to be as short as possible. How do we find how much weight we need to mount to the back of the arm?
Re: How to find the moment of an arm
once you have that, divide it by the distance from the fulcrum to (roughly) the center of gravity of the counter weight. that will give you the amount of weight you need. this doesn't factor in the material supporting the counterweight. if you're concerned about it being slightly off balance because this, you can use the above equation to find the moment of the material supporting the counter balance, subtract it from the moment of the 5 ft PVC arm, and then divide by the distance from the fulcrum to the center of gravity of the counter weight. final equation: 1/2(distance from fulcrum to end of arm)*(weight of arm)=1/2(distance from fulcrum to end of arm supporting counterwieght)*(weight of arm supporting counterweight)+(distance from fulcrum to CG of counterweight)*(weight of counterweight) welcome to the wonderful world of statics. Last edited by RogerR : 10-21-2004 at 03:49 PM. |
If it's in a scissor lift configuration, is there a load at the end of the Pipe? If so, that needs to be figured in as well by multipling the load times the distance from the fulcrum. Watch your units and make sure to gear down your motor so that it works at half it's stall torque to maximize its efficiency (except for the FP, Drill, and CIM - check Joe Johnson's / Paul Copioli's motor presentations in the White Papers section).
I = 1/3 *M*L^2 if that helps.
Thanks. We will get to work on the equations now.
not really
and its not stats, its mechanics.... if you can send me a diagram of how it works, i#m afraid i dont know what you mean by scissor lift..... |
Stats is usually short for Statistics, the science of making sense of large amounts of individually useless data. BTW a scissors lift is a non-trivial statics problem. |
Matt,
Am I understanding correctly that you're planning on deploying your scissor lift other than vertically? In my experience, that's a bad idea. You might be able to ameliorate problems if you have some (extreme) precision machining capabilities. But even if you do, you might want to reconsider your design. Consider that each joint in your mechanism will have some slop in it. This causes sag when the lift is deployed non-vertically. And each stage in your scissor mechanism compounds the sag. If you have very many stages, you will have a LOT of sagging going on out at the end of your arm. |
| WHich motor to lift and for arm | thoughtful | Motors | 8 | 02-25-2004 10:34 AM |
| Reflected Inertia? | archiver | 2001 | 9 | 06-24-2002 03:50 AM |
| Controlling Arm travel - Limit Switch or Mechanical Stop? | archiver | 2001 | 8 | 06-23-2002 11:55 PM |
| Correction for arm | skyfw | Programming | 6 | 04-06-2002 09:59 PM |
| telescoping arm & ten second rule | Ben Mitchell | Rules/Strategy | 4 | 02-18-2002 09:37 PM |
