Go to Post I Don't like to think in the Box so i try not to make robots look like them. - Tytus Gerrish [more]
Unread 30-10-2004, 11:38
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
Re: What teams have desgined a 6 wheel drive system?
6 wheels are awesome.... i would use them on ANY robot even 6" wheels and definitely 6 wheels are necessary for anything over 8" / pneumatic otherwise turning sucks.... the main thing is that the center wheel MUST be lower than the other two wheels otherwise its pretty pointless.... i guess you get more traction (and less turning) but with the center wheel our robot w/ 12" pneumatic tires, turned about 20 times better than our 2003 bot which had 4 wheels and 8" rubber tires
Team 701
Unread 30-10-2004, 14:07
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Team 356 has used a six wheeled drive system (with suspension) in 2003 and in 2004. In 2003 we had chips and drills driving separate wheels (with the front wheels being chain driven from the center wheels powered by the drills). In 2004, all six wheels were independently driven (chips, drills, fps).
In 2003, the front suspension helped us keep all six wheels on the ramp and top of the platform when we were attempting to take the hill.
In 2004, the suspension helped us climb onto the two platforms. We generally had 4-6 wheels in contact with a surface at all times.
2003, the Velvet Fog (http://www.chiefdelphi.com/forums/sh...light=team+356)
(http://www.chiefdelphi.com/forums/sh...threadid=17799)
2004, Wolfgang (http://www.chiefdelphi.com/forums/sh...ad.php?t=25833)
Unread 01-11-2004, 04:26
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
Team Role: Coach
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Team 980 learned about the 6-wheel drive system (with middle wheels 3/16" lower) from Team 254 and Team 60. They in turn credited Team 25 with the idea.
This idea was a breakthrough for us. Previously we had to keep gearing down our robot so that we could turn without blowing fuses (especially turning in place). This last season, using 6 wheels, our robot could spin like a top. We used programming to implement a reduced turning speed (with a button to over ride the programming if we had to turn really fast). We used gyros during autonomous, but not when our drivers took over.
In conjunction with Team 716's two-motor gear boxes (non shifting design
using drill and black motors from the Chief Delphi White Papers), our robot
was fast and maneuverable this year.
As it turned out, we also had some luck that the six wheel design
contributed to. Originally we hadn't planned on going up onto the platform
to hang, but then it turned out to be really hard to grab the bar from the
floor. One of our students discovered that we could do a wheelie (by backing up and then quickly going forward) and climb onto the platform which made it possible for us to hang quickly.
We had wanted to direct drive the middle wheels from the gear box, but we
couldn't fit the gearboxes (with drill motors, transmissions and gear boxes) side by side, so we wound up driving all six wheels with chains. It turned out to be very reliable using 1/4" chain. Basically the drill/black motor combination drove all three wheels on each side, so we got full traction although only four wheels were on the ground at any one time.
Sorry I don't have any drive train pictures, but you can see our robot on
our web site at team980.com.
Thank you Teams 254, 60, 716 and 25 (and many other teams who have
helped us) for sharing your ideas. They were a big help!!!
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 01-11-2004, 04:38
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
Doug has gotten to the heart of the matter here.
The 6-wheel drive with the lowered middle wheel GREATLY increases the turning of the robot. I know MANY teams who implemented such a system.
My main question is...
What distance do you drop your middle wheel?
I spoke to Steve from 254 and he told me they use 3/16" (as Doug mentioned above). I spoke to others who said they use a full 1/2".
What does everyone else use?
Lately, in all my pre-season design efforts I've used 3/16. I don't really have any good reason for it; other than Steve said it works for them. (And I LOVE their robot in action...)
Anyone?
John
In the interest of full disclosure: I work for VEX Robotics a subsidiary of Innovation First International (IFI) Crown Supplier & Proud Supporter of FIRST
Unread 01-11-2004, 08:30
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Team Role: Coach
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Anyone?
John
i've also heard 1/8"
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 01-11-2004, 10:52
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Rookie Year: 1997
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Anyone?
John
John-
Although it seems to make sense and would make design interesting we have never moved any of the center wheels from our machines out of line from the rest. We want the deep grab traction for the motors and pushing power. And I think any who play us will agree that the machines are speedy and maneuverable. We use two joystick tank drive on the machines and they can spin in place with no problem at all.
Perhaps the answer to this is the fact that we have such wide wheels (custom made from Skyway wheels) and a gearbox with great power. We are probably horsing the machine around so much when we turn that the coefficient of friction on the center wheel is negligible. We usually give the machines the "Big Mike" test- if they can shove him away they are strong enough. If we lowered the center wheel we negate the traction we are looking for back to 4 wheel drive.
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 01-11-2004, 12:08
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
Team Role: Teacher
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
we dropped our middle wheels just .1", and it worked fine for us.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 01-11-2004, 10:40
Rookie Year: 1997
Originally Posted by Rich Kressly
I'm not sure if Team 25 has Inventor files, but they graciously shared their 2003 Evil Machine design with Team 103 who used it on their 2004 bot Monkey Business. Team 103 used only four wheels, but adding the additional two is no problem at all (In fact 103 had two more wheels on just two weeks before shipping). The Team 103 version of the Team 25 drive system is well documented in the 2004 Inventor Website found here:
http://inventor.cybersonics.org
Here are some pics of the drive system of the team 25 recent six wheeled modular monsters. The whole robot pic is the 2002 robot Silver Scorpion- that made it to the final 4 in Nats. The modular drive pic is from Evil Machine 1- the 2003 finalist. As we've learned we have made the drives modular so they can be detached as a unit and replaced quickly. The kids strip them down and reassemble them like a soldier does with a rifle. The drives have never failed- never. They are now obsolete and the next generation will be a little faster and a little more powerful, at least according to prototypes. We have some new ideas up our sleeves. ; )
WC
Name:	closeup of the wheels and gearbox-sm.JPG
ID:	2582  Click image for larger version
Name:	look under the base sm.jpg
Unread 23-11-2004, 20:17
artic_raven's Avatar
artic_raven artic_raven is offline
Team Role: Mechanical
artic_raven is an unknown quantity at this point
Send a message via AIM to artic_raven
Originally Posted by Alex469
I know my team built a 6-wheel drive in 2002, but this was before my time and I don't know too much about it. The only pictures I could find on CD were here and here, but they probably won't help too much.
_Alex
is the bot still in tact or what?
if it is it would help me immensely if you could get a few pics of the motors and the way that it was all put together. if this is at all possible please help me out!!! thanks!
Unread 22-11-2004, 18:10
gavinb900 gavinb900 is offline
gavinb900 is an unknown quantity at this point
My team is thinking about 6 wheels. Has anyone experienced any problems with it? Does it go straight when its supposed to? Is turning smooth? Those are our main concerns right now. Thanks.
-gavin-
Unread 22-11-2004, 18:54
Ali Ahmed's Avatar
Ali Ahmed Ali Ahmed is offline
FRC #0004 (Team 4 ELEMENT)
Ali Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to behold
6-wheel drive is probably the best way to go. It will drive straight if your chains and everything is tensioned properly. The only problem with driving straight is in the gearbox of the Drill motors. But thats only in the gearbox and is easily fixable. For turning the best to do that is to lower the middle set of wheels so that when you turning you are basically turning on those two set of wheels. We haven't had any sort of problem with our 6-wheel drive systems yet.
Unread 22-11-2004, 20:20
RogerR's Avatar
AKA: Roger Riquelme
Team Role: Teacher
Originally Posted by ali_rockon22
...The only problem with driving straight is in the gearbox of the Drill motors. But thats only in the gearbox and is easily fixable...
if you're talking about the directional bias that the drills have (i.e., they spin slower in reverse), its actually built into the drill motors themselves.
independant 4 wheel drive ufa_mike Control System 21 07-04-2004 01:20
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
Championship Qualification - How you would've done it Ken Leung Championship Event 6 26-10-2003 14:00
Tank Stearing - 4 wheel drive Joe P Technical Discussion 12 04-03-2003 23:05
A new Forum newsletter Ken Leung CD Forum Support 4 01-10-2001 00:53
