MPLAB IDE 6.60 Error
I'm having a lot of trouble using the compiler from MPLAB. I downloaded the 6.60 version directly from this site: http://www.microchip.com/stellent/id...ame =en019469 . However whenever I try to compile code it gives me this error:
Couldn't locate build tool. Check tool locations. BUILD FAILED: Thu Nov 04 21:26:53 2004 Our team doesn't have the CD that comes with our Robovation kit, so we figured that the downloaded version would be the same. Is there anyway to fix this compiler problem, or at least use another compiler to build our projects? Thanks, Westerly High School Robotics |
| MPlab error | ryan_f | Programming | 9 | 24-05-2004 07:30 |
| Error message in MPLAB IDE | dddriveman | Programming | 11 | 18-03-2004 06:34 |
| Mplab startup error | Team 869 | Programming | 6 | 25-01-2004 10:41 |
| MPLAB IDE Project Specs | Raven_Writer | Programming | 18 | 19-01-2004 15:53 |
| using the MPLAB IDE MPLAB SIM simulator | WizardOfAz | Programming | 1 | 03-11-2003 01:24 |
