Go to Post FIRST is a life lesson on steroids. - JohnBoucher [more]
Unread 11-11-2004, 16:11
jdong jdong is offline
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
jdong will become famous soon enoughjdong will become famous soon enough
Adambots-Live Linux Makefile -- version 0.1 RELEASE
https://sourceforge.net/project/show...ease_id=281942
Notes:
This is a makefile that can be used as a Linux-replacement for MPLAB.
--Features--
Parses any MPLAB project containing folder (i.e. default code) and finds all the .c / .h files to compile
Uses WINE in conjunction with mcc18.
--Requirements--
It assumes that there's a /opt/mcc18 folder containing mcc18 in the SAME STRUCTURE as the Windows C:\mcc18.
It requires WINE. I've tested with 20040615 and 20040716.
Indent and Fortune are optional, but recommended.
The ifi-pictools or ifi-picloader packages are required to load the code.
--Operation--
Copy this file to the folder containing your code. Issue the following commands to get started:
gunzip [name_of_makefile]
mv [name_of_makefile] Makefile
mkdir .conf .deps
touch .conf/dummy
touch .deps/dummy
At this point, edit the makefile to modify its variables. Excuse the user-unfriendliness... It'll be improved / autodetected at a later version
Type (make target) to make a target. Possible targets:
(nothing) -- Generates FrcCode.hex file by building everything
file.o -- Compiles file.o from file.c
clean -- Removes compiled files, forces rebuild next time
prettycode -- Indents/reformats code.
load -- Use picloader to load the Hexfile to /dev/ttyS0
read -- Read robot output from /dev/ttyS1 (requires picreader)
Please test & comment.
File bugs at : https://sourceforge.net/tracker/?gro...94&atid=683416
File improvements / patches at: https://sourceforge.net/tracker/?gro...94&atid=683418
Need help? https://sourceforge.net/tracker/?gro...94&atid=683417
John Dong
Co-Captain, Webmaster / Programmer
Team 245 -- Rochester Adams Robotics
Fav. Beatles Song MattK Chit-Chat 17 04-12-2002 17:18
RoboIDE 0.1 (Linux PBASIC IDE) rbayer Programming 1 29-11-2002 14:48
