Re: which is better aluminum or steel????
I don't believe welding is a good option, it's just more machinery you need to bring to the competition. and I weld aluminum all the time, just cuz it's harder dosen't mean it's not good, no pain no gain. and correct me if i'm wrong but isn't there a no smoke or sparks rule, cuz they had that at our regional last year, and i don't believe that first would approve of welding while people are walking about without protective eyewear.
O ok, but the regional that my team went to last year didn't have those resources
Team 842 has used the fiberglass from Creative Pultrusions for several years. http://www.pultrude.com/ It's the material of choice for us. Several reasons: 5 times stronger than steel for its weight. Lightweight It can be worked with hand tools - drill, hacksaw, screwdriver. Field repairs could be made with a Swiss Army knife that has that little saw! If anything breaks, we can fix it in the pit wihout welding, machine shop, etc. Electromagneticly transparent (No radio wave problems) Won't corrode You can buy it in all kinds of forms: I beams, angle beams, round tubes, sqare tubes, etc. Its fantastic stuff. And .. no they don't sponsor us -- we tried, though. They should! Last edited by N7UJJ : 13-11-2004 at 10:43. |
yeah aluminum is definatly my metal of choice, i work in a machine shop and steel is alot harder to machine than aluminum, it's also usually heavier. hmmm that fiberglass sounds like it might be a good material, i'll have to check it out for my team.
im sure plenty of teams weld, but teams like us with limited resources and plenty of mistakes we find along the way, nuts and bolts are the best. so aluminum is probably "nicer" to the more rookieish teams
I’ve seen a lot of people talking about bolting and welding exclusively, and some saying they preferred bolting to welding since they thought it’d be much harder to repair a broken weld. May I suggest bolting, then having your frame welded with the connecting pieces on, and then taking the connecting pieces off (while keeping them around). This provides you the weight savings, while also allowing you to be able to make-shift bolt and problem you might run into. This is what we did on the robot I worked on last year. In fact, you can see some of the bolt holes near the joints of the frame. It may not be the prettiest thing in the world up close, but that can be worked around or designed in such a way that the bolt holes aren’t so obvious. We really didn’t care about the frame’s appearance last year; we just wanted to get it done.
(excuse the mess… there were 5 of us working for days on end, and ~30 straight hours down the wire… none older than 21) Picture 1 Picture 2 Picture 3 |
How come no one talks about riveting? Yet another alternative to welding (permanent) and bolting (removable but heavy).
Aluminum for the framing materials and steel rivets for the joins gives the best of all possible worlds... aluminum - very good strength to weight ratio steel rivets - semi-permanent, strong in shear and OK in tension |
#10
Go to home depot, and for $15 you can get a rivet gun, and for about $5 dollars you can rivet an entire frame. You just have to think a little bit before you rivet. Do it with reckless abandon, and you'll suffer. Do it well, and I think you'll come to love it. And for that extra bit of permanence - braze. Brazing aluminum is within the financial means and skills of almost every team as long as you follow safe work practices. For the low budget team, Burnz-o-matic makes a cheap kit that works (but the O2 gets pricey if you do too much.) I would encourage you to look up info on welding, brazing, and soldering - find out the difference. Rivets and Braze - what a good mix IMHO. Low cost and does the job. |
#11
And you can use a tiny, cheap rivet gun (about the size of an average hammer.) We did 1/4" rivets last year - that was hard. The rivet gun was actually called the "Big Daddy Rivet Gun". And you can get (2) 3/16" into a 1" X 1" spot. Sorry - I love rivets! Arrow's website, the rivets we use |
#13
As for the issue of cracking welds, if you have a good welds then you will not have a problem. If the welds are not coming out nice, then of course they are likely to crack. You can see a picture of our frame and the nice welds (lower structure, upper structure was a rush job) here picture For the frame itself, it is only 11 lbs. It is all 1/8" wall tubing. Thinking back, we probably could have gotten it down to about another 1/2 lb by going a little narrower on the tubing on the side rails. The only steel in our robot besides gears, sprockets, and chain is in shafts. All the shafts are steel but some of the larger ones are bored out through the center for weight savings. |
#14
Check out different alloys of aluminium. It makes a difference, but costs more. I think the kit frame was an alloy of sort, although I'm not sure what it was specifically. Anyone know?
#15
| Welding stainless steel to mild steel... can it be done? | Travis Covington | Technical Discussion | 3 | 27-01-2004 19:11 |
| Mini extruded aluminum | Ravi U | Technical Discussion | 7 | 17-01-2004 02:12 |
| Difference in aluminum | archiver | 2001 | 1 | 23-06-2002 23:49 |
| Let's get some aluminum extrusions | archiver | 1999 | 3 | 23-06-2002 23:12 |
| Legality of steel tubing. | newy | Rules/Strategy | 3 | 01-02-2002 09:16 |
