Go to Post You can't stop trying to look for other ways to do things, or that really defeats the whole purpose of inovation. - AmoryG [more]
Go Back   Chief Delphi > Technical > IT / Communications
  #16   Spotlight this post!
Unread 17-11-2004, 16:02
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Rookie Year: 1999
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: high speed internet help
Originally Posted by evulish
Actually, 802.11g has about a 10% shorter range than 802.11b. Also, any type of 802.11g device should work with any 802.11b device and vice-versa.. the 802.11g spec was designed to be backwards-compatible. I know this from experience since I have an 802.11b router, an 802.11g AP, 802.11g card, and an 802.11b adapter. They have all worked just fine together (the problem is between 802.11b/g and 802.11a). Also, if you're going to be using directional antennas, you're not going to get very good reception if you're moving around with a laptop.
I know from experience that there are G devices that do not work on B only devices. My roomates HP laptop has built in G, but does not work with B access points. I've heard of other people having problems, but I've seen the problems Justin has had. He got a USB B and uses that.
Wetzel
  #17   Spotlight this post!
Unread 18-11-2004, 01:10
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Rookie Year: 1999
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Originally Posted by Elgin Clock
Plus, to add to the b vs g wireless route, let's say you bought a laptop and wanted to connect to a wireless network at say the championship event.
G would let you connect, while B would not. (Been there, tried that )
G is the next generation wireless standard after B and is a lot more useful.
I connected just fine with my b wireless. It may have simply been where you were located. We'll see what happens this year
edit: If you do ending up hooking up to the Cable line, run a speed test and let me know what your results are.. Mine is 2595.4 Kbps and I am in the middle of a city area right now.
I'm just curious as to if it is reletively the same in a rural area with a 1500' individual cable line.
316.5 ( I'm running on sDSL with a guaranteed speed, will double in two months when I upgrade)
-Mike
  #18   Spotlight this post!
Unread 25-12-2004, 16:27
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Originally Posted by Wetzel
I win Elgin.
Wetzel
666.6 Kbps - You
I always knew SBC Yahoo was evil
http://www.mikesorrenti.com/
  #19   Spotlight this post!
Unread 25-12-2004, 17:47
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
Wetzel
Wireless devices are back-wards compatible, whether it be like the new internal HP wireless G cards, or an external B/G/pre-N card that you have installed in PCMCIA slots. Yes, you may have to configure setting with your router, or with the computer BIOS to have everything working flawlessly (as I to know there are "bumps" along the way). But everything flows in a wireless world. With networking and emerging technologies classes under ones belt you find ways to get by obstacles. I currently manage 3 wireless networks, and one hardwired network. I run internal b and g devices, and external b, g, and pre-n devices on Cable, DSL, and dial-up from Netgear to Linksys and beyond.
As for your communication dilemma, Ben - definitely start with your cable company. Check around with more than one office in your area, and you might have to contact several people in the process to make the correct contact. If cable is available to at least the main road, you may have to pay the price, but there is no reason you cannot be "hooked up". I have also dealt with situations where cable was not available, and you can contact neighbors and petition to have it run at the company's cost.
Best Wishes.
  #20   Spotlight this post!
Unread 25-12-2004, 18:11
Nick Fury Nick Fury is offline
Nick Fury has a spectacular aura aboutNick Fury has a spectacular aura about
I think some of this wireless myth and lore should be cleared up as there seems to be much of it in this thread. Where to start:
802.11g does not go further in distance than 802.11b. It all depends on the Amps and Antennas you have connected, nothing to do with the ethernet spec.
802.11b is not cheaper than 802.11g. Seriously, I have heard this one before and it in all honestly just depends on what you buy and where you buy it.
802.11b hardware DOES work with new 802.11g hardware because 802.11g is backwards compatible, I'm not sure what the problems you had were but it wasn't because the access point was 802.11g and you had an 802.11b card.
Now back to the subject at hand. Aside from calling your cable company (which is the easy way out and is what you should do). If you wanted to set up a wireless access point at the end of your driveway and run it to your house it wouldn't be all that hard. The first thing you need to get is a cable/DSL modem. After that you need an access point of some kind on the driveway end. If you can find an older access point that was made to use with the prism2 chipset PCMCIA cards then I suggest you get it (yeah it's only 802.11b but since when does a cable/DSL connection get more than 11mbs?) then I reccomend you pick yourself up some 200mW Senaeo Engenius cards (probably two of them). Now for power, you don't need 120vac.. what you need is the combined DC voltage of the modem and the access point.. this can be done in many ways (to name two: solar and power of ethernet). You are also going to need some sort of directional antenna, a good cantenna will work excellently. Now you are done on the driveway side of things. Next up you need something to recieve the signal and split it off to your various computers but this is why you bought the other wireless card. (also probably going to need a PCMCIA to PCI adapter) I reccomend a pentium 2 machine as a router.. add about 512 of RAM and you are set. Use a crappy HD and set up a small router linux distro on it. Throw in another ethernet card and run it out to a switch/hub and you are done. Now plug the rest of the machines in.
Now if this sounds like an absurd amount of work, well it is. I have done similar setups before and they aren't much fun to trouble shoot but it does make you feel good to put something like this together. Anyway, I reccomend calling the cable company, it's a lot less headbanging and frustration.
BTW the total cost for all of this crap would be around 200 bucks... not bad I say.
  #21   Spotlight this post!
Unread 25-12-2004, 19:33
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Rookie Year: 1996
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
There is another option I have not heard anyone mention - Canopy. It was designed for rural areas. Check this dealer in your state - not sure if they service your area, but worth a call:
http://www.jancommunications.com/motorola_canopy.htm
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
  #22   Spotlight this post!
Unread 25-12-2004, 21:23
Rookie Year: 1995
Whoops, sorry on my part, I was going to quote on that for you too in my original point. A network I set up in early Octoberish I ran into problems relating to this. The individual did not have a need or "want" for anything above or beyond a b, however I needed to make at least one desktop wireless as it was on a different floor (don't argue just play along ). With one desktop hardwired, and one wireless laptop I thought this was going to be an in and out project.
Just as a little warning to you - phasing out of b products is occurring. Depending on the company you want to work with (I personally have always favored Netgear, its all in ones opinion), you may easily pay more for a b product than a g or super-g (enhanced) product. So keep a heads up when you are shopping for what you may need.
  #23   Spotlight this post!
Unread 26-12-2004, 04:14
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
I would defenitely reccomend staying away from satelite internet. We had it for a year till we could get DSL last september and its not all its cracked up to be. The latency of the connection is what stinks, it was always at least double that of regular dial-up, so it takes just as long to load pages and surf the net. Downloading is great on it once you have established a connection - easily outstripping any dsl or cable connection, but it has a rather low download limit of 160 Mb per 4 hours.
We also had trouble with it being improperly installed the first time, which led to the service cutting out regularly (daily, or every couple of days) and being easily swayed by the slightest bit of weather. Once it was reinstalled correctly, which took at least 7 months to get them to do as well as a couple hundred to cover the pole for mounting, it worked much better in that it hardly ever cut out. It still had bad latency (ping times between 1500 and 3000) and still had a very annoying download limit that you could max out in 15 minutes if you tried, then you were completely cut off for 4 hours.
Anyways, thats my experience with it.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Joining 2 dif. motors K.Shaw Motors 32 14-10-2004 19:40
Multiple teams from one high school? KathieK General Forum 24 28-06-2004 16:30
Metro high school students win national robotics contest Brandon Martus FIRST In the News... 0 24-03-2004 17:00
How fast is your internet connection? Wetzel Chit-Chat 56 10-10-2003 15:40
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
