Edu Robot Multiple Inputs
I am having some serious problems with our innovation first Edubot. For touch and IR sensors, we can get the code to work with one sensor just fine, but if we try and use two inputs then we get weird results. I was wondering if anyone else has experienced this same problem? If so, what did you do to fix it? if anything? Thanks for you help.
Re: Edu Robot Multiple Inputs
Check the initialization to make sure that the inputs you are using are, in fact, inputs.
I extended the wait time in the code, from 10 to 30 and the wierdness went away. (see function Get_Analog_Value) note, there is a warning in ... * FILE NAME: ifi_utilities.c * USAGE: * The user should NOT modify this file, so that if a new version is released Jerry W |
| what kind of robot will win? | Bcahn836 | Championship Event | 44 | 12-04-2004 00:02 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Important functions of a first robot? | Ianworld | General Forum | 5 | 15-04-2003 13:29 |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
| We're really not that mean. | archiver | 1999 | 59 | 23-06-2002 22:49 |
