Workstation video card
hey everybody
We are looking at possibly building a computer for our animation/cad since our school computers can't handle it. I hope i got this thread in the right place, also, sorry if i didnt. Anyway, does anybody have any recommendations on what video card to use? I was thinking possibly an Nvidia QuadroFX 700 or an ATI FireGL, paired with an Intel Pentium4 3.0GHZ and 1 to 2 GB of RAM. Any suggestions? there will of course be the things like hard drives/CD drives etc. etc. Let me know of any suggestions, and don't worry about explaining the technical stuff, like that i need a socket 478 processor or whatever, as i do have some knowledge about computers. thx pat |
Re: Workstation video card
I don't really think you need that killer of a card, unless you don't have a budget limit, if not then maybe you should look into dual xeons =D
EDIT: I'm not too sure about animation, but for CAD, I use Inventor on my laptop, which has a ATI Mobility Radeon 5700 - 16MB Video RAM; lag isn't too bad. |
You may want to read this thread :
http://www.chiefdelphi.com/forums/sh...ad.php?t=31034 There was a similar discussion there that might help. |
I'll second that notion. You don't really need a workstation class video card for animating unless you have an unlimited budget. Here's why:
A spiffy super hot video card will only make modelling a little quicker and less jumpy. It also might make previews of your animation run a little faster or smoother. I think you'd be better served spending less money and getting a fast, (not bleeding edge) video card. Like something 6-months or a year old. Then spend all your money on a really fast processor and lots of ram. Also, you might look at the price for an AMD socket-939 based system as well, as they apparently are faster than pentiums in some rendering applications. A faster processor and more ram will cut a lot of time off your rendering, which is what really matters. Also, If you have money left over after this spending spree, try to get a second box together. 3DS max will let you spawn an install onto other machines to use for network rendering so you can spread the workload and get things done even faster. |
thanks for the suggestions
We have about a 1000 dollar budget, and we will meet it easily. If we didn't have a budget however.... Dual Opterons Nvidia Quadro FX 4000 16 GB of memory OH YEAH!!!! But seriously, does anybody know whether ATI or Nvidia will perform better? THe FireGL's are cheaper on newegg.com, but idk if the performance will be less.... |
From my experience (which is very little), CAD requires a lot more processor power then video card capabilities, so I guess it depends on if you are doing CAD or Animation. My crappy laptop with a 64 meg integrated video card runs inventor fine with a 3.0ghz CPU. Either way an Intel processor with 3.0+, HT possibly is a must. If you are going all out, I guess FireGL with PCI-Express. Ah yes and lots of RAM .... don't let your CAD die because you run out of memory (happened to me yesterday) and loose 2 hours of work.
For Inventor, I use a P4 2.4GHz,512mb RAM, Abit IS7 motherboard, 10K RPM SATA HD, Geforce FX5200 128mb video card. It works really well. There is some minor glitching with the Geoforce video card in inventor, but for the most part I like it a lot. Autodesk actually has a table on their site that shows what video cards are recommended and which ones aren't. Sadly, I don't believe my Geforce is a recommended one so maybe something like a Radeon would be better.
Here's the main things that I see as necessary for a CAD computer to function well. P4 Processor (Preferably 2.4GHz+) 512mb - 1Gb RAM Video card with 128mb memory decent motherboard/chipset |
ok, got it, quadro/fireGL videocard is overkill...
so basically its mostly processor power. weird. I am used to apps where its all about the video card. THis comp is being designed primarily for the 3ds Max, with possible CAD also. Would it be better to go AMD Athlon 64? I know that these are best for gaming and other 3d apps, but better for animation also? And if we could manage it, we could do maybe up to 4gb RAM and a sweet video card, possibly an nvidia Geforce 6800GT. Possible system specs, not including drives, etc. Pentium4 3.0+ 4GB RAM (PC3200) Nvidia 6800GT? or AMD Athlon 64 3000+ or better 4GB RAM (PC3200) Nvidia 6800GT? or whatever video card would work well. We do want this system to last quite a while. Last edited by Skiwreck : 29-11-2004 at 22:46. |
#11
A hard drive can have a big effect on animation. Loading large uncompressed video in and out of memory can slow things down. Western digital 10,000 rpm SATA drives are fast. Two in a raid configuration are even nicer. If you do go with Raptors, pay close attention to the power supply and thermal loads. Compressing video is demanding on memory. Spend some money on good memory. Tom's Hardware has some reviews of work station cards. Most work station cards are optimized for openGL. If the programs you use are not OpenGL or a mix, you might want to look at a high end game card and save some money. Don't forget the monitor. Animation is best done on big screens LCD or CRT and they're expensive. What I'm trying to point out is take the money you have and try for a balanced system and don't just focus on the video card.
#12
As for your other questions, from my experience: AMD's are known to be much faster and cheaper than Intel processors, but Intels usually last longer/are more reliable, and are better at multi-taking capabilites (especially if you have hyperthreading), which could be a good thing for Animation. ATi's and nVidia cards are about the same in speed and quality; ATi is just slightly faster, nVidia cards seem more reliable, usually. Personally, I always go with Intel and nVidia products. With a 1000 dollar budget, I'd stick with an AMD processor and an ATi card and stuff a lot of fans in there. The more powerful components you get the more complications you're going to need to resolve (like excess heat and power consumption, all which take more money). Oh yeah, and I second the post above. |
#13
He DOES however want to use this computer to do animation. Well, here is the bottom line, the better the card you have, the faster it will render frames. If CAD is your main concern, then it's not soo much a big deal. |
#14
Here is how a variety of workstation cards compare on a variety of applications: http://www.spec.org/gpc/opc.data/vp8/summary.html
#15
4GB of RAM seems like a bit much. Perhaps tone that down to 1GB and get a little bit slower processor (2.8GHz) and a little bit cheaper graphics card and perhaps squeaze two computers out of your budget?
| Review: Felis Catus vs. New Video Card | Joe Matt | Chit-Chat | 0 | 01-10-2004 22:24 |
| Yellow card / Red card usage at 2004 IRI | Andy Baker | Rules/Strategy | 53 | 02-08-2004 00:35 |
| Im looking for a video card and need some help | D.J. Fluck | Chit-Chat | 21 | 04-08-2002 10:53 |
| Anyone know how to tape a webcast? | archiver | 2001 | 5 | 24-06-2002 04:02 |
| Good video footage | miketwalker | General Forum | 0 | 28-03-2002 17:14 |
