Go to Post Not even close to ready...can we delay it till like...January 2010? - Cory [more]
Unread 02-12-2004, 17:01
Code\\Pilot Code\\Pilot is offline
< Only smart people see my avatar
AKA: Rafael Estrada
FRC #1065 (Tatsu)
Code\\Pilot is an unknown quantity at this point
Send a message via AIM to Code\\Pilot Send a message via MSN to Code\\Pilot
Using the extra buttons on the joystick.
Does anybody has an idea of how to use the extra buttons on the joystick?
Because the only bits mapped are the trigger bit and the top button bit.
And there is more buttons there that we could use.
Any ideas?
Join the Red revolution, give me some RED rep!!!!
if it doesn't work, don't force it. Go get a bigger hammer.
int run = 0;
int robot_chasing_you = 1;
if (robot_chasing_you)
run = 254;
I got 48 Gmail invites left, pm me with your e-mail so i can send you one.
Unread 02-12-2004, 17:11
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Re: Using the extra buttons on the joystick.
Any ideas?
I know there are more buttons in the default code.. such as the hat switch and the 2 aux buttons next to the hat. (p1_aux1 & p1_aux2)
If you have another kind of joystick that isnt given by FIRST or working with the default code, you can find out how it works with a multimeter and a little bit of time.
First, find a Pin-out diagram for standard Game Port connectors. Set the multimeter to detect continuity and put one lead on the pin used for input voltage. Then hold down a button and put the other lead on pins until it beeps (or flashes.. depending on the meter). Repeat this for each button and make sure to write down what button connects to what pin. (use the voltage measuring feature to find which joystick axis connects to which pin)
Then, find the corresponding pins in the default code (look in "ifi_aliases.h" for the variable names of each pin) Then set an alias in your "user_routines.h" file. Could look something like this:
Code:
#alias MyJoystick1_SideButton       rxdata.oi_swA_byte.bitselect.bit3
Unread 02-12-2004, 17:52
AKA: Rafael Estrada
FRC #1065 (Tatsu)
Didn't find any for the hat switch... any ideas?
int run = 0;
run = 254;
Unread 02-12-2004, 18:43
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
You need to disassemble a joystick with the extra buttons and see where they are connected. Many joysticks wire the extra buttons, hat included, through resistors to the postive power supply. This is equivalent to using an analog input with a switched resistor as shown in the RC/OI manual. Using a meter in the continuity mode will not tell you if you are at the end of a switched resistor string. Use the "ohm" mode and check for varying resistance. Don't be surprised at the shoddy workmanship on the inside of some of the better known joysticks.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 02-12-2004, 20:41
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
AFAIK, the hat and top buttons are not even wired up in the joysticks that come with the Kit of Parts. I remember not being able to get feedback from them last year, and taking one apart to discover that the wires from the switches were not actually connected to anything. Anyone wanna back me up on this?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 02-12-2004, 20:58
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Hat switch: http://www.chiefdelphi.com/forums/sh...ad.php?t=24315
Unread 02-12-2004, 22:51
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
Lightbulb Re: Using the extra buttons on the joystick.
contact the manufacturer
Unread 04-12-2004, 19:30
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
They are, but they're flaky. In our pair, one has a bad top and the other has a bad base.
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
problem with joystick buttons (top left one) Richomundo Programming 5 15-02-2004 17:16
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
