Go to Post I have a feeling this is going to be a really good year.:) - Richard Wallace [more]
Go Back   Chief Delphi > Other > Math and Science
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
  #16   Spotlight this post!
Unread 05-12-2004, 21:36
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Re: Turn 90 Degrees
A potentiometer.. or "pot" for short is a electrical component that increases or decreases resistance to flow based on the position of a lead which is attached to a cylinder. A common use for these are volume controls or light dimmer switches.
We can use these on our robots by utilizing the analog input pins. These pins are able to read an analog value, which will give you the amount of voltage flowing into them, rather than just a 1 or 0 from a digital input. As the resistance increases in the pot, the analog value on the RC goes down because more voltage is being dropped in the pot. So, using that value we can figure out how far something is rotated.
The difference between a multi turn pot and an encoder is that one is analog and one is digital. A multi turn pot works on the same basis as a regular pot, but it is able to revolve many times. An encoder is basically a switch that gets turned on a set number of times in a full rotation.
  #17   Spotlight this post!
Unread 05-12-2004, 22:22
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Turn 90 Degrees
Originally Posted by MikeWasHere05
Yes, thanks
Glad to hear it. PM me if you have any issues with implementing this, and be sure to stop by and say hey to team 1388 when you go to Atlanta.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Six Degrees of John V-Neun Amanda Morrison Chit-Chat 47 24-07-2007 18:11
G4 wont turn on! MattK General Forum 14 26-08-2003 09:44
College Advisor turn outs Guyute General Forum 4 20-06-2003 13:35
Yaw Rate Sensor to 90 degrees? Bruce C. Programming 4 11-02-2003 00:36
PWM Antonio Technical Discussion 21 06-01-2003 14:44
