Go to Post Warning: This thread is long like a Ken Leung post........... but about 47 times less interesting and insightful. - Brandon Martus [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 07-12-2004, 00:03
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Motherboard Monitor
Does anyone here use motherboard monitor? I got it today because my computer was lagging while playing a game and was generally slow. This software is awesome. I found out that my CPU was over 100 degrees hot! Also, my power supply shows only like -7.6V for the -12V supply and only like -3.7 for the -5V supply so I think it is dying. Also, my chipset fan is varying in speed between 2000 and 7000 rpm.
I opened up the case and since it had been a while it was filled with dust. I blew it out and now the temperature is only 89 degrees. But my power supply is still low, and my fan is still varying in RPM (and is kind of loud). So, I'll replace the power supply, and then see if that pesky little fan is any happier and finally see if my game runs better.
So anyway, if you don't have it, Motherboard Monitor is a really cool little program.
So if you've got it, post your stats.
Also, I should probably get off CD and shut this beast down for the night. I don't want low voltages to cause harm to any components.
Computers monitor going funny Denman Chit-Chat 10 05-12-2004 18:38
What size monitor do you use? Elgin Clock IT / Communications 30 10-03-2004 16:53
What resolution do you use on your monitor? Elgin Clock IT / Communications 29 17-02-2004 22:10
Downloading Problem to EDU Motherboard Jankenpoe Programming 0 16-02-2003 14:29
VB Program to monitor robot variables DanL Programming 7 15-02-2002 22:35
