Go to Post Keep in mind that words can be harsh and people do not forget what is said against them. Please, for your teammates sake, keep your egos in check and try to use some tact and consideration. - Andy Baker [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 11-12-2004, 16:20
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
CAD/CAM softwear
I recently got the CAD/CAM softwear called BobCad. It allows for you to open drawings of other softwear and drop a part into a CNC, and machine it throught computer. It would be pretty useful if it worked.
The problem is that the softwear doesnt support *.dwg files, which are the files that Inventor and AutoCad use for drawings. Does anyone know of a way to convert *.dwg files to another format?
Thanks
Unread 11-12-2004, 16:24
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
Re: CAD/CAM softwear
AutoCad/Inventor can save files into a number of different formats, one of which is surely compatible with your software (if it isn't, your software is junk). Just click File | Export... (at least in AutoCad) and select the filetype you wish to use.
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Unread 11-12-2004, 20:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Perhaps look into the IGES, STP and DXF file types.
Unread 11-12-2004, 23:17
Ah yes. That certainly helps. Thanks guys!
on a side note, does anyone else have BobCad? If so, how do you use it? (not literally, I mean what do you do, use its built in CAD or drop in drawings, if so from what softwear)
