Has any team or anybody made a 80% - 100% lexan bot?
I'm looking for pictures and any details on a robot that is made of lexan or any other material then metal. It goes with all these posts.
**I'd like to add a note this is for my senior project and it will be done before the start of the season and i will be doing extensive testing on the durability of the materials chosen, since we will be going to 3 competitions this year. 6 wheel bot Belt Drive Drive the 6" wheels thanks! pictures if possible Last edited by Alex Cormier : 11-12-2004 at 22:46. |
Re: Has any team or anybody made a 80% - 100% lexan bot?
I believe 1038 had a frame made of lexan in 2003.
Here's a picture of it...it was acrylic and was apparently not used because of "design flaws."
http://www.chiefdelphi.com/forums/sh...threadid=17366 Hope this helps. -Steve |
190 made their 2003 chassis out of lexan, it was SICK! they had no problems until battlecry when the lexan split right down the middle of the robot
that was an easy 6-7 events before they had a fatigue problem. |
SPAM team 180 has mad robots, even the gear boxes were out of lexan i believe. I belive this one below was called lexy.
Edit- andrew, spam is a great team. and yes they have made 3 robots out of lexan. none of the robot broke during the competition. the past three years (2002, 2003, and 2004) they used aluminum as their chassis. for a game like we had in 2003 (Stack Attack) i wouldnt build a robot using lexan. but still you never know, you might be able to come up with something very solid. Last edited by Arefin Bari : 11-12-2004 at 20:43. |
Engineering is about designing such that the materials used can withstand the forces applied. It's true, a robot chassis made out of graham crackers (my default, "weak material" for examples) probably wouldn't hold up. However: lexan, aluminum, steel are all TOTALLY doable. Lexan's main advantage is it bends quite a bit before exceeding the elastic point. However, this is also a disadvantage when it comes to chassis design. Aluminum is much more rigid, and rigidity is important for some chassis applications. Enough rambling... my point is: Lexan is a totally viable chassis material, and I'd be more worried about it bending and throwing a chain or something than worried about it breaking. John edit: Despite it's "bendability" (there's a fun fake word) Lexan can STILL be used effectively. Check out the above picture of 180 and see how they got around it. Note the cross bracing and box stucture (very high rigidity). Good stuff. Last edited by JVN : 11-12-2004 at 20:45. |
I don't have any numbers off the top of my head, but I'm pretty sure lexan is horrible in most strength(tensile strength, etc)/weight ratios compared with aluminum. I'd venture to say a good quality plywood will even exceed polycarbonate.
#10
Also, I agree that lexan is much more expensive than aluminum, and 190 would probably not use it if we didn't get it donated every year. In fact, in 2003, the lexan that was donated to us was Hyzod AR, which is a pain to work with due to its abrasion resistant coating, and normally costs $300-$500 for a 4'x4' sheet (about twice what normal lexan costs). |
#12
What you posted doesn't "mesh" with what I thought to be true. Can you go to www.matweb.com and get the actual values, and report back your results? I'd do it, but I'm working on something else right now. Can anyone out there do this for me? I'd really appreciate it. Maybe a comparison between 5052 H34 aluminum or 6061 aluminum, and whatever common grade of Polycarb McMaster-Carr sells? That would be awesome. Real enginerding -- you betcha! Thanks, John Last edited by JVN : 11-12-2004 at 22:59. |
#13
is this what you wanted John?... http://www.matweb.com/search/Specifi...snum=MA5052H34 ... thats for 5052 H34 Aluminum... here are few examples of 6061 Aluminum... http://www.matweb.com/search/Specifi...ssnum=MA6061AO http://www.matweb.com/search/Specifi...assnum=MA6061A here is an example of lexan.... GE Plastics LEXAN EM1210 Polycarbonate http://www.matweb.com/search/Specifi...snum=PGE8NA117 Last edited by Arefin Bari : 11-12-2004 at 23:18. |
#14
I was already on it, and would have had it posted before you, John, but Firefox crashed
![]() I used ultimate tensile strength as other websites have suggested it is the standard for strength-to-weight calculations. I would have thought yield strength is more appropriate, but I can't find that data for Lexan. GE Lexan (clear, no glass) ---72 MPa -----1.2 g/cm3----- ratio 60 Aluminum 6061-T6 ---------310 MPa -----2.7 g/cm3 ---ratio 114 for comparison: very strong titanium ------- 320 steels have an incredible range of like 40-250 but as far as I can tell (I'm not sure what are the most common types), structural steel is in the 80-110 range. Amazingly enough, a high quality piece of wood (European ash, is good, apparently) can have a ratio as high as 320! in the direction of the grain though it is a mere 12 perpendicular to the grain. I'm trying to find some good data on plywood, but it looks to be approximately equal to PC (but of course it is bidirectional, unlike regular wood.) carbon fiber ----------------3200 kevlar----------------------2100 I know that what is generally considered the strongest material ever created was carbon nanotube fiber (spun by some of my dad's former co-workers ) but that is using some other measurement of strength (I believe Young's modulus).Note that the properties of these extremely high tensile strength fibers aren't simply comparable with steel and aluminum. You can't build a robot 20 times lighter out of carbon fiber. Last edited by Max Lobovsky : 11-12-2004 at 23:50. |
#15
Thanks a lot. It is always nice to see someone back up their argument with numbers. Props to you, AND to Arefin for taking the time to do some research (Which is very important when doing design and analysis.) You guys rock, John |
| The Death of FIRST | Anton Abaya | General Forum | 23 | 03-05-2006 17:18 |
| How do you organize your team? | NoodleKnight | Team Organization | 18 | 03-11-2005 22:57 |
| Thank a Team with an i-Pod !!! | OZ_341 | General Forum | 8 | 20-04-2004 23:57 |
| Team 524's bot | Amadkow | Robot Showcase | 2 | 27-02-2002 20:36 |
| Novi Kickoff Seminar List (Tentative) | Joe Johnson | General Forum | 1 | 05-12-2001 13:47 |
