Re: Has any team or anybody made a 80% - 100% lexan bot?
Thanks a lot. It is always nice to see someone back up their argument with numbers. Props to you, AND to Arefin for taking the time to do some research (Which is very important when doing design and analysis.) You guys rock, John |
Funny, there haven't really been any references to plywood in this thread.
For my team's first 2 years we used 3/8" plywood. Though in 2002 we had this large steel "knee breaker" apparatus that was used to grab ahold of goals. In 2003, however, the only metal you could see on the robot was the angled alluminum, 1/4-20 bolts and lock nuts used to hold the chassis together. It was sweet. |
MrToast ![]() |
Additionally, Polycarbonate varies (you'd have to go to some other brand than Lexan) and glass filled PCs have ratios around about 80. I'm pretty sure glass filled PC is too hard and brittle for most framing use. Last edited by Max Lobovsky : 12-12-2004 at 10:05. |
And just because the use of this by teams that have plenty of metal machining capabilities annoys me:
pipe type PVC ------ ratio 31 |
Team 346 (Richmond) made one in 2001, I believe it was. There were a couple of pieces of aluminum angle connecting the Hyzod platform to the side panels. Each side was doubled up and contained a chain driving 3 wheels. It looked very much like one of those WWI tanks, as the front was intended to crawl over the 4x4 in the middle of the playing field. The polycarb was appx. 3/8" if I recall. I don't have pictures, but perhaps someone from 346 does. The frame held up well, although the bot was pretty light.
Since this thread has turned to a choice of materials discussion, I would like to point out that in the past 3 years I have noticed a increase in rough play in the game. In 2004 we took several high impact hits. We fortunately survived them with no damage. I would suggest that all teams look at the materials and design with the goal of surviving high speed point impacts. More and more teams are using multiple motor trans and the power and speed is increasing. Plan for it or you'll find you self in the pits making emergency repairs. What worked in the past may not work as well for 2005.
First has opened up the allowed materials. Evaluate the choices and use them. |
| The Death of FIRST | Anton Abaya | General Forum | 23 | 03-05-2006 17:18 |
| How do you organize your team? | NoodleKnight | Team Organization | 18 | 03-11-2005 22:57 |
| Thank a Team with an i-Pod !!! | OZ_341 | General Forum | 8 | 20-04-2004 23:57 |
| Team 524's bot | Amadkow | Robot Showcase | 2 | 27-02-2002 20:36 |
| Novi Kickoff Seminar List (Tentative) | Joe Johnson | General Forum | 1 | 05-12-2001 13:47 |
