Go to Post It's kind of magical how I went from legos to replacing most of the iron in my blood with aluminum, and all thanks to my elementary school science teacher. - Astrokid248 [more]
Unread 20-12-2004, 08:13
atmaturen atmaturen is offline
atmaturen is an unknown quantity at this point
Send a message via AIM to atmaturen
Question boolean
ello all,
i've seen to have forgotten how to declare a boolean variable...
any help would be greatly appriceated.
thanks in advanced.
(wow, my spelling is vile)
Unread 20-12-2004, 09:25
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: boolean
There is no boolean variable type in C. Most people declare it as char (or unsigned char) and use the value 0 for false and 1 (or any value != 0) for true.
Through the use of #defines and typedefs, you can emulate it, though.
Code:
typedef unsigned char bool
#define TRUE 1
#define FALSE 0
Then just use the variable type bool and the values TRUE and FALSE.
Unread 20-12-2004, 09:26
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: boolean
There isn't an explicit boolean type.
Typically, you use "char"
Unread 20-12-2004, 17:40
Re: boolean
do the boolean functions (and & not) work this way?
Unread 20-12-2004, 17:48
colt527 colt527 is offline
AKA: Ken Colton
FRC #0527
colt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to behold
Send a message via AIM to colt527
Re: boolean
I'm not 100% sure if this wouldn't work, but my original thought would be it wouldn't.
char boolVar = 1;
if(boolVar)
//Do this
but for && and || and != they all work the same:
char var1 = 1;
char var2 = 0;
if(var1 == 1 && var2 != 1)
//do this
Mentor, Team 527 -- Plainedge Red Dragons
FIRST Volunteer
SUNY Stony Brook Computer Science 2010
kcolton@gmail.com
Unread 20-12-2004, 17:52
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: boolean
Use this (http://www.lysator.liu.se/c/bwk-tutor.html) as a reference and you should be OK.
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 21-12-2004, 17:56
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: boolean
In reply to previous concerns:
As long as you use the logical operators (&& || !) instead of the bitwise ones (& | ~ ^), you shold be ok.
If you need to use == and !=, I would recomend using one of this macros around the operands (the values being compared).
Code:
// CBOOL Converts to BOOLean
#define CBOOL(val) ((val) ? TRUE : FALSE)
// LOGically EQuivalent
#define LOG_EQ(val1,val2) (CBOOL(val1) == CBOOL(val2))
// LOGically Not EQuivalent
#define LOG_NEQ(val1,val2) (CBOOL(val1) != CBOOL(val2))
Unread 28-12-2004, 00:28
jude's Avatar
jude jude is offline
#0116 (Epsilon Delta)
jude is on a distinguished road
Send a message via AIM to jude
Re: boolean
You can get rid of the #defines by using an enum:
Code:
typedef enum {TRUE=1, FALSE=0} bool;
There's also a small practical benefit for this approach:
Some compilers will be able to do some extra type-checking against the enum values, and warn you if you accidentily try to do something like "bool b_Var = 5".
Code:
#define TRUE 1
#define FALSE 0
Unread 28-12-2004, 12:49
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Re: boolean
Assuming you're using MPLAB/CBOT, I think the #define method would be best. The method to use though is completely based on what makes you happy.
There's honestly countless number of ways to accomplish though. Like I said though, I think the #define method is best *not to mention, very short on the lines side*
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Boolean statement blindguyinanorg Programming 2 15-02-2004 07:31
