Go to Post ... simple things can amaze me. - Andy Baker [more]
Unread 20-12-2004, 13:57
doyler doyler is offline
Rookie / Programmer
#0900 (Infinity)
doyler is an unknown quantity at this point
Rookie help
I am new to programming and extremely new to a lot of mechanical stuff in general, so my team gave me something to work on over the holidays, but I am very confused.
I will try and be as specific as possible to receive help
They gave me an edubot controller, a battery, a charger, 2 servos, a serial to usb converter, and something called a BEI GyroChip
I know what the battery, charger, and serial -> usb cable do/are for, but how would i hook up the rest of thie stuff to the control
Thanks
Unread 20-12-2004, 14:52
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Rookie help
Originally Posted by doyler
... 2 servos, ... and something called a BEI GyroChip
... how would i hook up the rest of the stuff to the control
The servos plug into any PWM available on your controller. Setting the value (0-254) of the PWM will turn the servo to a particular spot. The same spot everytime you use a particular value.
The gyro plugs into an analog input on the controller (one of the first inputs based on User_Initialization() in user_routines.c). If it doesn’t already have a connector attached you’ll have to make one out of a PWM cable. You get values from it doing something like “x = Get_Analog_Value(rc_ana_in01);“ The neutral position of the gyro will be close to 512. When the gyro is twisted slowly in one direction you’ll get numbers between 0 and 512 only while you are twisting it. Do the same in the other direction and you’ll get numbers between 512 and 1023. If you keep track of these numbers you can tell if your robot is driving straight or not and correct. It can also be used to make precise turns, to say 45 degrees if you calibrated it.
This particular gyro is no longer "street legal" to use on your competition robot, but it's good to learn with. This one will be overly sensitive to turns or sudden movements that are too quick, and will more easily lose track of the original robot heading.
Do a search on “gyro” for a lot of threads on the subject.
Unread 20-12-2004, 15:14
Rookie / Programmer
#0900 (Infinity)
Re: Rookie help
the gyro has a pwm, and my only job is to make the sensors move or something
sensors go to pwm out? if so, the black is on top right
the gyro goes to analog in with the black on botton?
if all this is correct thank you and i will probably have questions later about what all these do and what / how to code
Unread 20-12-2004, 15:21
Just Itinerant
Re: Rookie help
Yes, black on the outside, or the pin furthest from the controller, of each connector.
The gyro is a sensor and the servos are specialized motors.
Unread 20-12-2004, 15:30
Rookie / Programmer
#0900 (Infinity)
Re: Rookie help
um, i have 4 pwm out pins, but only three holes, does the closest one not matter for these servos?
Unread 20-12-2004, 15:33
Just Itinerant
Re: Rookie help
Leave the inside pin unconnected. It's a duplicate power pin.
Unread 20-12-2004, 15:41
Rookie / Programmer
#0900 (Infinity)
Re: Rookie help
I can use any 2 pwm out pins right
And I just put the gyro in the first digital in spot
Unread 20-12-2004, 15:47
Just Itinerant
Re: Rookie help
Yes, any pwms will do for the servos.
If you are starting with the default EDU code, that arranges for the first two inputs to be analog, so either 1 or 2 will work.
Unread 20-12-2004, 15:49
Rookie / Programmer
#0900 (Infinity)
Re: Rookie help
Will the default EDU code have stuff that i can just upload and make it work, just to learn the workings?
Unread 20-12-2004, 15:55
Just Itinerant
Re: Rookie help
Yes. Start with that. Also get the EDU documentation from the innovationfirst.com website:
http://innovationfirst.com/FIRSTRobo...04-Jan-14a.pdf
http://innovationfirst.com/FIRSTRobo...10-15-2003.pdf
http://innovationfirst.com/FIRSTRobo...t_02-16-04.zip
Unread 20-12-2004, 16:01
Rookie / Programmer
#0900 (Infinity)
Re: Rookie help
And I just use MPLAB IDE to mess with it right?
Also, what kind of code am i looking for just to make these things move for starters
What code(s) will I have to upload as well?
Rookie 2005 Nats Qualification? Alexander McGee Championship Event 2 27-10-2004 10:14
Senior Project 05: Mini competition to help fundraise for local rookie teams Alex Cormier Fundraising 0 07-10-2004 15:58
Rookie Regionals rachakate Regional Competitions 5 24-03-2004 00:01
I want to have a rookie nationals! Tton Championship Event 5 23-04-2003 14:46
