Go to Post Imagine a world solely consisting of FIRST students. Oh the things that we could do. - Ryan Himmelblau [more]
Thread Tools Rating: Thread Rating: 6 votes, 3.67 average. Display Modes
Unread 22-12-2004, 13:05
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Victors Non-linear!!!
I have confirmed a suspicion i have had for a while. Apparently the victor 884's do not have a linear PWM input vs. voltage input.
A DVM was attached to a victor and the values recorded while incrementing the PWM input by a set number every 6 seconds. The reason for the initial values being a bit sketchy is that i was using a cheap digital meter that fluctuated a bit. As time went on, i got a little better at figuring what number it was hovering around.
Here i attached an unloaded motor to a victor and measured its speed vs. victor PWM input. The speeds were determined using a 1024 count optical encoder encoder. The motor was a fisher-price motor w/gearbox.
The test was automated and did the following:
1.set victor output
2.wait 2 secs for speed to stabilize
3.count encoder ticks for x secs. (I think the test was set to wait 3 seconds at the time this data was taken).
4.output data
5.increment pwm output and goto step 2 unless finished
Note that since the motor is unloaded, motor models dictate that speed should be directly porportional to the input voltage of the motor.
I should mention that these tests were done on a single victor 884 and i cannot guarentee that all victors behave similarly although i believe that they do. I also believe that this curve is a feature of their design.
There will be higher resolution data as well as code examples of how to compensate for this to come. It will probably be a while as i am busy with other things and will be out of town all this week.
I hope my imagehost holds up
1139 Alumni
24Vs and victors greencactus3 Control System 13 05-02-2005 14:22
Calibrating Victors SpaceOsc Control System 27 19-11-2004 07:59
Flakey Victors archiver 1999 4 23-06-2002 21:58
DON'T Recalibrate Victors! Joe Johnson Off-Season Events 0 12-11-2001 22:58
