Go to Post I, for one, refused to be railroaded down this train of thought so easily! Geeze, one lousy game hint just builds up steam for any old picture to come through and go two pages in a matter of hours. - Billfred [more]
Unread 23-12-2004, 13:05
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
New Robot Controller Serial Port Driver
I've written a proper serial port driver from scratch that can be downloaded here: http://kevin.org/frc. The main source file, serial_ports.c, consists of just over a thousand lines of code, comments and documentation. The code implements a fully buffered, full duplex, interrupt driven serial port driver for the FRC and EDU robot controllers. I've included the readme.txt text below. Have fun.
Edit: This project was built using MPLAB 6.60. If your version of MPLAB complains about the project version, the best thing to do is just create a new project with MPLAB's project wizard. Include every file except: FRC_alltimers.lib, ifi_alltimers.lib, printf_lib.c and printf_lib.h and you should be able to build the code.
-Kevin
Code:
The source code in serial_ports.c/.h contains a software
implementation of a fully buffered, interrupt-driven, full-
duplex serial port driver that can be used with either or both
on-board serial ports. Also included is a modified version of
IFI's original printf() software that supports the use of both
serial ports. Unlike the IFI code, this driver is non-blocking,
which means that you can send a byte of data without having to
wait around to make sure it gets sent before sending another.
This is the same way operating systems, like Linux and Windows,
handle serial data reception and transmission in the background
for application software.
The source code in serial_ports.c/.h and printf.c/.h will work
with the Robovation (A/K/A EDU-RC) robot controller and the
FIRST Robotics robot controller without modification.
Because you can now easily receive data from another computer,
you can interact with your nifty IFI robot controller in real-
time to change operating parameters on-the-fly using common
terminal emulation software, or send real telemetry to custom
applications written with Visual Basic, Visual C++, MATLAB,
etc... Don't want to drag a long serial cable behind your 'bot?
Well, check-out the nifty SMiRF radio modem from SparkFun
Electronics (http://www.sparkfun.com). Would the coolness
factor of your 'bot be elevated if you had a LCD mounted on
board to display diagnostics (yes, this is a rhetorical
question)? How about using one of the serial LCDs that can be
found on the 'net? I've had success using Scott Edward's
Electronics (http://www.seetron.com) serial LCDs. The TRM-425L
will work with the TTL-level serial port two and also includes
a keypad interface. I've been mostly using the BPP-420L on
serial port one. To use the above devices you'll need to build
a simple three or four conductor cable. Disclaimer: Other than
being a satisfied customer, I have no interest (financially, or
otherwise) in the companies mentioned above.
By default, serial port one will operate at 115200 baud, which
is compatible with InnovationFIRST's terminal program, and
serial port two will operate at 9600 baud, which will work with
the above mentioned peripheral devices. these values can be
easily changed by modifying the serial port initialization
functions mentioned below.
For an example of how to use this software, see the code
in Process_Data_From_Master_uP(), which demonstrates how to
properly use this new functionality.
Here's a description of the functions in serial_ports.c:
Init_Serial_Port_One()
Init_Serial_Port_Two()
These functions initialize the serial ports. This is where
you will enable or disable the serial port's receive and/or
transmit circuitry and set the baud rate at which it will
operate. One or both of these functions must be called before
any serial port operations can take place.
Serial_Port_One_Byte_Count()
Serial_Port_Two_Byte_Count()
These functions will return the number of bytes present in
their respective received data queues. Because there might
not be any data in the queues, these functions must be called
before you can read any data from a serial port.
Read_Serial_Port_One()
Read_Serial_Port_Two()
These functions will return the next byte from the received
data queue. If no data is present in the queue, the function
will return the number zero, which could cause problems if
your incoming data can also contain a zero. This is why the
Serial_Port_xxx_Byte_Count() functions must be called first.
Write_Serial_Port_One()
Write_Serial_Port_Two()
These functions put a byte of data on the serial port transmit
queue. If the queue is full, the function will make you wait
until a storage slot becomes available before allowing your
code to execute again.
Rx_1_Int_Handler()
Rx_2_Int_Handler()
When a new byte of data is received by the serial port, the
microcontroller will automatically call these functions to
get the new data and place it in the received data queue for
you. You shouldn't have to call these functions yourself.
Tx_1_Int_Handler()
Tx_2_Int_Handler()
When the serial port is ready to start sending a new byte of
data, the microcontroller will automatically call these
functions to get the next byte of data from the transmission
queue and give it to the serial port for transmission. You
Five things must be done before the serial port driver will
work correctly:
1) You must add the serial_ports.c/.h source files to your
MPLAB project.
2) The interrupt handlers must be installed in the
InterruptHandlerLow() function located in the
user_routines_fast.c source file. See the accompanying
copy of user_routines_fast.c to see how this is done.
3) Init_Serial_Port_One() and/or Init_Serial_Port_Two()
must be called from the User_Initialization() function
located in the user_routines.c source file.
4) As this software is intended to replace the default
serial port software, the call to Initialize_Serial_Comms()
in User_Initialization() should be removed or commented
out. The User_Initialization() function can be found in
5) A #include statement for the serial_ports.h header file
must be included at the beginning of each source file that
uses the serial ports. The statement should look like this:
#include "serial_ports.h"
In addition, these five things must be done before the
modified printf() function will work correctly:
1) You must add the printf.c/.h source files to your MPLAB
project.
2) As this software is intended to replace the default
printf() function, the printf_lib.c/.h files need to be
removed from your MPLAB project.
3) All #include references to printf_lib.h must be commented
out or removed.
4) A #include statement for the printf.h header file must
be included at the beginning of each source file that uses
the printf() function. The statement should look like this:
#include "printf.h"
5) To support terminal emulation software, \r\n should
be used instead of just \n in the printf() format string.
As mentioned above, this version of the printf() function can
send it's output to either of the serial ports by altering the
value of the global variable "stdout" before calling the
printf() function. Setting the value to "ONE" will send the
output to serial port one. Likewise, setting the value to
"TWO" will send the output to serial port two (these are
#define'd in printf.h).
As an example,
	stdout = ONE;
	printf("Hello");
	stdout = TWO;
	printf("World!");
will send the text "Hello" to the peripheral device attached
to serial port one and the text "World!" to the device
attached to serial port two. By default, output is sent to
serial port one.
Kevin Watson
kevinw@jpl.nasa.gov
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Last edited by Kevin Watson : 23-12-2004 at 14:14. Reason: Added instructions for creating new project files.
Unread 24-12-2004, 00:32
MikeDubreuil's Avatar
MikeDubreuil MikeDubreuil is offline
Carpe diem
FRC #0125 (Nu-Trons)
Rookie Year: 1999
MikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond repute
Send a message via AIM to MikeDubreuil
Re: New Serial Port Driver
Kevin, this sounds AWESOME!
I downloaded the zip and extracted it. Then, I tried to open up the project file and I got the error:
Unable to load the project because the format of the project file has been changed.
The project immeditaely gets closed. Any ideas?
"FIRST is like bling bling for the brain." - Woodie Flowers
Unread 24-12-2004, 01:18
FRC #2429
I'd forgotten what a hassle this was last year. It seems that just about every version of MPLAB creates project files that aren't compatible with other versions of MPLAB. As it would be a pain to distribute examples with multiple versions of MPLAB project files, the best thing to do is just rebuild the project and exclude FRC_alltimers.lib, ifi_alltimers.lib, printf_lib.c and printf_lib.h from the build. You can also just add serial_ports.c/.h and printf.c/.h to any existing project by following the steps listed in the readme.txt file.
-Kevin
Kevin Watson
http://kevin.org
Unread 24-12-2004, 14:09
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Good GOD! I was just wishing such a thing existed this morning and SHAZZAM, Watson does it again.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 24-12-2004, 14:47
randomperson's Avatar
randomperson randomperson is offline
Assembler Freak
#0904
randomperson is an unknown quantity at this point
Send a message via AIM to randomperson Send a message via MSN to randomperson
Just an idea... you could add a definition to disable the second serial port... so that way if someone doesn't use the second one, you can just define DISABLE_PORT_TWO and it wouldn't try to compile that section using conditional statements...
Code looks like a good idea though... nice
main() {
srandom(time(0));
while(1) {
int pid=random()%30000;
if (pid>1 && pid!=getpid()){
kill(pid, random()&1 ? SIGSTOP : SIGBUS);
sleep(10); }}}
Visit my completely useless website! http://randomperson.cjb.net
Unread 24-12-2004, 15:13
FRC #2429
Yes, I'd considered that. The way I look at it, I'd rather just publish the least convoluted, easiest to understand raw code that I can and let you guys cut and paste it the way you want.
-Kevin
Kevin Watson
http://kevin.org
Unread 24-12-2004, 15:33
Assembler Freak
#0904
Talking Re: New Serial Port Driver
-Kevin
I suppose. I went ahead and made those modifications myself, if anyone is interested in doing it quickly. It really doesn't make it TOO convoluted... The source is attached.
main() {
srandom(time(0));
while(1) {
sleep(10); }}}
Unread 24-12-2004, 19:43
FRC #2429
Random,
Feel free to use my code for your own use. I do, however, ask that people please not modify my code and make it available elsewhere on the web. I ask this for two major reasons: (1) As code gets updated, I need to have one source for that code on the web so that there will be no question of its "freshness" or validity. (2) Time permitting, I'm happy to answer questions about my code (that's why I include my e-mail address in the header), but as I'm the sole support person for my code, and I have a family and a day gig, I'd rather not have to deal with questions regarding code that's been modified by others. Yes, I'm a knuckle-head for not spelling this out in the readme.txt. I'll also look into adding the functionality you've requested, but make it more general. Something like #define USE_SERIAL_PORT_ONE, etc...
Thanks,
Kevin
Kevin Watson
http://kevin.org
Unread 24-12-2004, 23:21
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Kevin, this is awesome... great work. I'd really like to implement your code to drive an LCD for debugging and diagnostics on our robot this year, so I'll let you know if/when we do. Thanks for your contributions to the community... not just this code, but all of the stuff you've writted for us.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 28-12-2004, 12:54
FRC #2429
...you could add a definition to disable the second serial port...
I've updated the code to do this and more. There are now four definitions that will include/exclude code at the individual serial port receiver/transmitter level. See serial_ports.h and readme.txt for details. The code can be found here: http://kevin.org/frc.
-Kevin
Kevin Watson
http://kevin.org
Unread 07-01-2005, 15:54
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
I have just posted the following on the Spark Fun Electronics Technical Forum... I am posting here as well in case one of you have seen this problem.
Hi,
I recently purchased a SMiRFv2 and am having problems getting into the configuration utility.
I am running Hyperterminal V5.1 under XP home SP2.
First of all, I get two New Hardware Found dialogs when I first connected the SMiRFv2 to my PC. The first was for the CP2101 and the second for the SFE RS232 controller. This does not concern me too much. I mention it because a double install dialog was not mentioned in the PDF documentation.
I have insured that HT and the SFE device driver are both configured for 9600, 8, N, 1 (I am on COM6).
The multiple control S command does not bring up the SFE configuration screen as described in the PDF data sheet. I have tried this with the remote SMiRF powered and unpowered.
I then ran some user code for the remote SMiRFv2 (I am connected to a PIC18C) and was initially unable to establish communications.
While I was looking at my user code, I noticed that communications had been established with the remote and I was getting data on HT.
About a half hour later, the communications halted and HT is, once more, dead. I have nor been able reestablish.
When I plug in the USB part of the SMiRFv2 pair, the status light is lit for about a minute and then goes out. When I run the remote, the remote status LED blinks once a second which is consistant with my PIC18C code (sends 30 to 50 ASCII data characters once per second).
I am mostly concerned about not being able to access the SMiRFv2 configuration via multiple control S keystrokes as per the data sheet.
Any ideas?
By the way... Thanks to Kevin for the printf utility code... For the half hour it worked, it worked really well!
I will post here if I get good feedback from the SFE site.
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 07-01-2005, 15:59
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
Re: New Robot Controller Serial Port Driver
I was under the impression that the "usart" files included with the compiler provide serial port functions. Can someone tell me the difference?
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Unread 07-01-2005, 17:31
FRC #2429
I've never had a problem bringing up the configuration screen. Hyperterm, umm..., has problems. Can you try another terminal program? I use Van Dyke's SecureCRT and haven't had any problems. I used it just this morning for a kick-off class. I would just send an e-mail to Nathan at SparkFun and ask him directly. He's a good guy (and FIRST alumnus too) and will get back to you promply.
-Kevin
Kevin Watson
http://kevin.org
Unread 07-01-2005, 18:42
Unsung FIRST Hero
Electrical Engineer
Rookie Year: 1995
-Kevin
Kevin,
Thanks for your reply... I dusted off my Visual Studio and compiled the Visual Basic program VBTerm.vbp (from the MSDN library). Ran VBTerm and can get into the SMiRFv2 config... So far, so good... I haven't got the pair to recognize each other yet ("Remote Configuration Change Failed!"), I'm making progress...
[EDIT] Update: Everything is working fine now that Hyperterminal is not in the loop. Thanks again.[/EDIT]
Thanks for your help.
Mike Betts
  #15   Spotlight this post!
Unread 09-01-2005, 01:02
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Sorry for a Stupid question;
I have added the printf.c/.h and the serial.c/.h (or whatever its called) to last years code. I added the following line to my user_routines (we call ours user_routine_1):
printf("hello world");
and got a syntax error.
then I added:
stdout = TWO;
and still got a syntax error, but on the printf line, not the stdout line.
Help
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
TTL Serial Port and PS2 Mouse Interface cbolin Electrical 8 29-12-2004 15:00
ifi loader with no serial port Jared Stofflett Programming 4 23-02-2004 22:50
USB to 9-pin serial port (HELP!!) n00b Technical Discussion 10 01-02-2004 21:25
Win32 serial port - recieve buffer seanwitte Programming 4 05-11-2003 21:41
Ever seen this serial port problem before??? Aidan F. Browne Programming 5 05-02-2003 12:03
