Go to Post that Martus character always has a way to take care of them. - Ricky Q. [more]
Unread 24-12-2004, 11:24
rmmlg's Avatar
rmmlg rmmlg is offline
#0900 (Infinity)
rmmlg is on a distinguished road
Shifting Transmission
What is the experience that anyone has had with shifting that uses dogs versus shifting that uses crashing gerars? If you have been able to get crashing gears to work without tearing up teeth, then have you had trouble with this method at some point, and if so, then what have you done to fix it?
Ryan
Team 900 (Infinity)
Unread 24-12-2004, 11:42
Arefin Bari's Avatar
Arefin Bari Arefin Bari is offline
AKA: Ari
FRC #0108 (SigmaC@T)
Arefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond repute
Send a message via ICQ to Arefin Bari Send a message via AIM to Arefin Bari Send a message via MSN to Arefin Bari Send a message via Yahoo to Arefin Bari
Re: Shifting Transmission
There are pros and cons to both designs. i have seen both dog and mesh shifter work on a first robot. Efficiently team 45 (technokats) has done dog shifting and 180 (SPAM) has done mesh shifting. personally i am supportive to both shifters. but mesh shifter is probably easy to build (i am not an engineer YET). but i am sure that Andy Baker from 45 and Gary Dillard from team 180 can tell you about both shifters...
Unread 24-12-2004, 13:55
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Rookie Year: 2000
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
http://www.usfirst.org/robotics/2004...vetrainmdj.ppt
this is from the conference at the Championship last year. Hopefully this should give you a lot ideas and many pros and cons of different drive trains/ transmissions.
http://www.chiefdelphi.com/forums/pa...er&paperid=386
This is a link to a whitepaper done by team 33...very interesting 4 speed gear meshing transmission....
good luck
Unread 24-12-2004, 15:12
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
I myself am a big fan of the dog style shifter but from the designs I have looked at, the key to a crashing gears setup is the low D.P. on the gears which make for not only stronger teeth but also much more room between them. From what I have seen something like 15 pitch or even lower. However some of the other designs like to one in another thread the gears look pretty standard such as 32 pitch so I am not sure.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 24-12-2004, 15:53
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Bill Gold just posted a video of mesh shifting with 24 pitch gears, and I believe that is what team 60 has used for the past several years. The one thing I see with a mesh shifting system, is that while it is simpler to design and build, it requires more gears and more "stages" in the gearbox. First, you have the motor stage, let's say it is the Chiaphua. Then you have the reduction stage with a big gear that mates with the motor gear and with a long small gear also. Then you have the sliding stage with two gears, the bigger one one mating with the long small gear in the previous stages. Then you have the final/output stage which mates with the sliding stage, depending on which direction it is slid in. So, I'm counting 4 stages and 7 gears. In a constant mesh dog style transmission, Like Matt's or Andy's from 2003, you have only 3 stages and five gears (with only the Chiaphua) because the second stage doesn't have to slide along a previous stage, it stays put and the dog does the gear selection.
Unread 25-12-2004, 00:05
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Rookie Year: 1998
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
That is not neccesarily true. One big reason they have so many gears is because they eliminate any sort of chain reduction entirely and drive the center wheels from the output shaft of the last gear stage. I think that a meshing system could have the potential to have less gears if done in a slightly different manner than they do it. Either way, they obviously have an elegant solution and it seems to be working great for them.
I will still put my vote in for the dog style transmissions. Of course
Also, Dave, drop me a line sometime. We are creating a service learning class next quarter with the ME department so we can get credit for helping out the high school FIRST teams. You might be interested.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
Slickest drive transmission yet... dlavery Technical Discussion 58 10-01-2005 19:33
The perfect 2 speed Transmission..... features... Salik Syed Technical Discussion 28 20-10-2004 11:44
3 shifting transmission... Arefin Bari Technical Discussion 19 04-03-2004 01:24
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
