Re: White Paper Discuss: Nothing But Dewalts
I have a couple quick Questions.
Has anyone had problems removing the chuck off the end of the drill? And How did you end up getting it off? We are having problems with it and we need some help! |
Yes, we had trouble. Ended up using heat and impulsive force; i.e., torch, punch, and hammer. That loosened the (left) threads so we could get the chuck off. The trick is using just enough heat and impulsive force to get the job done, and not enough to break things. We had a very experienced tech-ed teacher lead the students through the exercise.
There is screw that must be undone that is inside the chuck. I believe that it is reverse threaded. To get the rest of the chuck off, we used a socket wrench with a long lever attached to it. To interface the wrench with the chuck we used a hex adapter (something that fits in the socket and is hex-shaped at the other end). The adapter also needs to fit into the chuck. Tighten the chuck around the adapter and use the wrench to carefully unscrew the chuck.
Hope that wasn't too confusing... ![]() |
It is easier and cheaper to order individual parts as per the NBD White Papers.
Dewalt has a great website http://www.dewaltservicenet.com And YES they can be shifted with a simple servo. |
Give us a call and if you need clamshells, help or advice we are willing. 254-501-0987 Joe P Team 647 Shoemaker Cyberwolves |
Can someone explain the purpose of the plastic "top hat" for the CIM modification? Is it some sort of bushing to support the shaft? Is it absolutely neccesary? Do the screws holding it to the carrier gear actually need to transfer much torque, or is it just to press it up to the gear?
Normally, the ring from the first gear stage keeps this second ring from tilting, but with the entire first gear stage removed, there is nothing but air to do this. As to torque, there is no torque needed at all. In fact, there is no reason to have more than 2 screws. We just used 4 because there were four planets on gear stage one, which suggested to us to use 4 screws. Absolutle overkill. Joe J. |
Alright, so there is no reason to even widen those holes (hardened steel isn't so fun to machine). Just find some small enough screws or other fastener.
In fact, if you could find a washer with at 5/16 hole and 1.650 or so OD, you could probably eliminate the tophat entirely (together with the above and a standard 5/16 washer) Good thinking. Joe J. |
#10
The paper suggests that "software synchronization" may be possible for shifting the transmissions. I believe I understand what synchronization is in a shfting transmission; it's waiting until whatever you are shifting is lined up with whatever you are shifting into so that no grinding of gears or shifters occur. Now how could this apply to the DeWalt transmission? How could you tell when the gears are in the right position to shift?
#11
First off I want to say that this is a great white paper. It makes it a lot easier to start more teams in an area with a small mentor base with ideas like this and AndyMark. I can't wait to try my first DeWalt transmission!!
I do have a couple questions while I wait for my order to come in. What modifications are required to the fisher price pinion? Has anyone mounted a gear to 1/2" shaft? My first impression is that a gear would produce a smaller side load but without a transmission in hand I may be missing some issues with mounting accuracy. Thanks again! |
#12
same for me.......did anyone toss a spur gear on the drill output last year......if so with what implications?
#13
Modify motor adaptor Make a plate that holds motor to adaptor Get Planet2 from extra transmission, enlarge hole to 1/8, press off 13T that is on FP, press on 1/8 bore Planet2 onto FP Mix well... ...Done! Quote:
Joe J. |
#14
thanks for the fast reply. just for the record Dr. Joe....Dennis and I are using six dewalts so far. in fact it's nothing but dewalts except for the globe motor, but he didn't need any help.....so he's flying solo.
i don't have one in hand yet, but we're excited to give em a go. |
#15
I just checked the status of my Dewalt order. I had been hoping to see part of the order waiting for me when I got home today. When I placed the order, the motor adapter was on backorder until 1/24. Now it’s listed as back ordered until 2/11, and this was an alternate, P/N 626494-00. But this may be entirely moot because the transmission is now listed as out of stock and no back order date is listed. Hopefully the local service center is open tomorrow and can help me out.
| White Paper Discuss: Users Guide to Autodesk Inventor | CD47-Bot | Extra Discussion | 2 | 18-12-2006 17:45 |
| White Paper Discuss: Comparison Paper for Teacher Involvement | CD47-Bot | Extra Discussion | 1 | 13-11-2004 00:09 |
| White Paper Discuss: Karthik's Championship Event Data | CD47-Bot | Extra Discussion | 20 | 13-04-2004 08:17 |
