Go to Post The short answer is there is no shortcut. - JDNovak [more]
Unread 03-01-2005, 11:39
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
Worm Gear Gearbox
Has anybody on a FIRST Team every tried to create a gearbox using worm gears. I would like to try to do this, it seems very interesting to me. Even tough they are not always very practical for drive trans it seems as tough that it might have a competitive advantage. Since when you cut the power it will not roll back in the opposite direction. If anybody has any questions, suggestions, or any other usefull information please post it here.
"I'm sorry, after all he is just a wookie!"
Unread 03-01-2005, 11:51
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: Worm Gear Gearbox
258 used worm gears to power their arm with two CIM's this year. They have some pictures posted here on CD you could look at, and I'm sure Bill Gold would be willing to explain what they did to you if you asked.
2001-2004: Team 100
2006-Present: Team 254
Unread 03-01-2005, 12:26
Dr.Bot
Posts: n/a
I did this as an experiment using the plastic gearboxes, shafts and axels suplied by first and purchased gears - there is a post somewhere of someone else who did this. The Chippawa moters fed into this I think it was a 30 fold reduction - so the speed was about 4fps. So comparable to a Fischer Price, but much more powerful, Unfortunately my entire robot platform was thrown out in a fit of spring cleaning - the gears cost about 300 bucks for two sets.
I had some pictures, put heck if I can find them.
SO worm gears will work, and you can make the transmissions with just a good drill press if you are carefull and precise.
I got the gears from "Boston Gear"
worm GH1076RH gear G1071RH
Unread 03-01-2005, 13:10
Unsung FIRST Hero
Bill Gold Bill Gold is offline
Retired -- 2006
Rookie Year: 1999
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
Like Cory said earlier, the team I was on last year (258) used a CIM to power our shoulder joint, and the other CIM to power the elbow joint in our arm last year. Each CIM ran into its individual gearbox, and then powered their joint via #35 chain/sprockets. In each gearbox the CIM was reduced with spur gears at a 3:1 ratio, and then reduced another 60:1 with a 60-tooth worm gear and a single thread worm (worm ratios being # of teeth in the gear / # threads on the worm), and then there was a sprocket reduction of 4:1 to the joints.
The cast iron worm gears didn’t crumble, and the only problem we had was due to some “over-engineering while under-thinking.” Long story short, we use nuts to hold the worm in place on its shaft, but didn’t think about the nuts loosening up due to the rotation of the shaft (which they did). So, after a while the nuts would back up, and when we tried to rotate the arm with all of our robot’s weight behind it (like trying to “chin-up” to hang) the worm would slightly slide out of place, and end up stalling the gearbox/motor. If we had just machined an aluminum spacer instead of using those stupid nuts, that arm would have perfectly accomplished all it was designed for. Oh well, live and learn…
Our worm gears were ordered from Martin Sprocket…
10DP 60-tooth worm gear (W1060)
10DP Single Thread Hardened Worm (WG10)
http://www.seadawgs.com/1.JPG
http://www.seadawgs.com/2.JPG
http://www.seadawgs.com/3.JPG
http://www.seadawgs.com/4.JPG
http://www.markrobot.com/gallery.php...ncoln%2F17.jpg
http://www.markrobot.com/gallery.php...ncoln%2F41.jpg
http://www.markrobot.com/gallery.php...ncoln%2F46.jpg
http://www.markrobot.com/gallery.php...ncoln%2F42.jpg
I’ve also seen many other uses of worm gears in drivetrains and other robot mechanisms. They can be great for situations where you don’t want backdrivability, or for a huge reduction in a relatively small amount of space. As with any gear-to-gear setup, be sure you have the ability to machine your gearbox fairly accurately, or else you’ll get either binding or huge backlash (or no gear contact at all). If you have any questions about these gears I’d suggest checking out an informational .pdf that Boston Gear has (http://www.seadawgs.com/GT.pdf), or go into Borders/Barnes & Noble and skimming through (or just buying) The Machinery’s Handbook. There’s tons of great stuff in both of those.
I hope this helps.
-Bill
Unread 04-01-2005, 04:51
Jizvonius's Avatar
Jizvonius Jizvonius is offline
AKA: Jevawn Roberts
FRC #1002 (CircuitRunners)
Rookie Year: 1997
Jizvonius is just really niceJizvonius is just really niceJizvonius is just really niceJizvonius is just really nice
Send a message via AIM to Jizvonius
I will vouch for the workability of the worm gear gearbox in a drivetrain. In 02 my high school team tested it. Just make sure that you pay attention to the forces that your gearbox will be subject to, and lube like a madman. The forces don't work out the same as with spur gears as there is more axial force on the worm gear and worm, so putting a large amount of force through a worm gear gearbox can cause an improperly considered structure to flex and bind even if you were precise in your machining. (it can still work just design the box structure and shafts to take the forces)
Also make sure that you check the torque ratings on your gears. The fact that they don't backdrive also means that much of the shock of hits goes soley to the teeth of the worm gear.
We also got our gears from boston gear.
Unread 04-01-2005, 07:49
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
Last year we used worm gears to power our shoulder mechanism for the first part of the UTC regional. We removed the arm primarily because it unbalanced the robot.
We adapted the FP motors to go into the Bosch transmissions. On the output of the transmission we had a six point socket attached. The socket interfaced with a bolt that the worm was welded to. The worm assembly was setup with 4 bearings, 2 flange type radial and 2 thrust. The worm wheels were soid mounted to our shoulder shaft and the motors and transmissions were mounted to the arm. It worked well for moving the arm and locking it in place with no back drive, but alas few ever saw it work properly for many reasons.
Pete
Unread 04-01-2005, 08:17
Jim Schaddelee's Avatar
Jim Schaddelee Jim Schaddelee is offline
Team 107 Holland Christian / Metal
None #0107 (Team Robotics)
Team Role: Mechanical
Rookie Year: 1997
Jim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud of
Team 107 also used a worm drive transmission a few year ago,it work ok but there are things to be aware of. The main issue is your reduction should not exceed 50 to 1 on the worm ,for the reason that it will not back drive or coast. You can compensate for this by adding a ramp down in your code, but in humble opionion worm tranmisson is better suited for arms or lifting or any application where there are not sudden loads ,like stopping a moving robot.
I may still have one of the transmission we used if you would like me to sent it to you to look at I would be happy to help. I will try to post some pictures of a new worm tranny I designed over this summer If anyone would like to see it.
thank jim schaddelee
team 107 Holland Christian / Metal Flow
Unread 04-01-2005, 10:40
dddriveman's Avatar
AKA: Driveman
Talking Re: Worm Gear Gearbox
I would love to take a look at that worm tranny. If you do not mind sending it to me. You can find my email in my profile.
Unread 04-01-2005, 11:53
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Worm Gear Gearbox
I don't want to jump in and be a nay-sayer... but I think one of the things you need to really weigh in before considering a design using a worm gear is the immense efficiency loss you're going to have simple due to the nature of the gear set.
We're talking in the range of efficiencies as low at 30% !
The advantage you mentioned, about not being able to back-drive the gear set, is not always true. There is some critical pressure angle and coefficient of friction that leads to the point were you actually can back-drive this gear set. Jim said that it's above a reduction of 50-1. I can't verify this either way.
[edit: But Paul definitely can. Rock on!]
However, simply because of the efficiency issue, I would steer clear of them in a drive-train gearbox unless there's a really good engineering justification. For a large reduction in a small amount of space, an off-the-shelf planetary gear set would probably hold better efficiencies.
That's my two cents. Good luck
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 04-01-2005, 13:27
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
Back Drive-ability is a function of surface finish, lubricity, and worm lead angle. Using a bronze worm gear and a hardened steel worm (the small screw looking one), the max lead angle is 5 degrees to insure self locking. This is not a guarantee! What is a guarantee is that above 5 degrees, the worm gear set will not lock. The lead angle is the reason the window motor locks and the van door motor does not lock. It really has nothing to do with the gear ratio. A gear ratio of 50:1 with a lead angle of 15 degrees will not lock.
However, the more thread starts on the worm, the higher the lead angle and the lower the gear ratio is. Remember, gear ratio for a worm gear is # of teeth on the gear divided by number of thread starts on the worm.
-Paul
Unread 04-01-2005, 15:25
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
a little off, but for lego, wormgear 24:1 reductions work very well, for lego robots i mean. not too slow, yet (well since lego isnt efficient whatsoever,) efficient (make sure you wupport both axles from both directions, and since lego axles are plastic, support them as close to the gears as possible.
well, yea. worm gear gear boxes (wormgearboxes?) as an idea are very applicable ithink. except as with designing any kind of gearbox, will have difficult parts but if it works well, great!
...and yea, im understanding why my english teachers rarely give me any good grades on my essays.
Unread 04-01-2005, 15:47
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
Actually efficiency might not be an issue if you properly design the gearbox. A little bit of engineering and you should be able to get the efficiency fairly high. Of course a little research shows that the efficiency can reach 60%.
Article
Ps. Please someone build a drivetrain using these gears. These are the funniest sounding words ever. Hypoid and globoid.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 04-01-2005, 16:25
Cory's Avatar
AKA: Cory McBride
Article
60% efficiency is still downright terrible for a drivetrain when you consider spur gears are 98% efficient and chain is 95% efficient
2001-2004: Team 100
Unread 04-01-2005, 16:26
Rookie Year: 2000
Here are some facts about worm gear efficiency:
Efficiency = Tan(Lead)*(1-f*Tan(Lead))/(f + Tan(Lead))
Lead = Worm Lead Angle
f = Coefficient of Friction (Mu)
For a bronze gear and a steel worm f = 0.05
Easy to purchase worm gears have lead angles ranging from 4.5 degrees to 22 degrees. Here is the bounding range on efficiencies
Lead angle of 4.5 degrees has an efficiency of about 61%
Lead angle of 22 degrees has an efficiency of about 87%
This assumes everything is lined up!! Tolerances are very critical for a worm gear set-up.
The lead angle of 22 degrees corresponds to worms with 4 thread starts and the lead angle of 4.5 corresponds to worms with 1 thread start. The worm with one thread start has 4 times the gear ratio for the same package size than the worm with 4 starts. A worm gear box has several advantages for FIRST robots. The main two are package size and weight. We have used worm gears on our robots for three years, but only once on our drive transmission (see white papers under CCT).
  #15   Spotlight this post!
Unread 04-01-2005, 16:36
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
I'm going to have to strongly disagree about efficiency not being an issue.
Even with your research, which I won't refute, 40% losses in a single stage of a gear set is still quite large compared to the 10%-15% losses over an entire drive train with spur gears and chain.
It should be noted that Adam's article did cite a 97% efficiency for a multiple stage gear train using worm gears, which I found to be quite impressive. (Costs? Yikes! )
Worm gears have their place, but I would strongly discourage their use on a drive train if you're just looking to reduce your gear ratio. I'd definitely like to see justification addresing the losses, which we can all admit are several times larger than spur gears.
(See Paul's link for an appropriate application.)
Matt
gears Michael Leicht Inventor 12 16-09-2004 10:52
Reverse Gear FizMan Technical Discussion 12 26-04-2004 01:29
Van Door Worm Gear Jim Giacchi Motors 4 16-12-2003 09:35
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
